April 2, 2019, 05:29 |
outletPhaseMeanVelocity - interFoam
David Smith
Rep Power: 13 |
Hi everyone.
I am running DTCHull tutorial in OF. At the outlet, in the tutorial, boundary condition for velocity is outletPhaseMeanVelocity. outlet { type outletPhaseMeanVelocity; alpha alpha.water; Umean $Umean; value $internalField; } Do you know what is "value" is used for? Is it the dummy value that used for visualization in Paraview? My case is a little bit unusual as I have non uniform velocity at the inlet. For uniform velocity, it is easy to setup simulation and run without mass conservation issue. For non uniform inlet velocity, this BC finds a hard time to balance mass between inflow and outflow. |
September 26, 2024, 07:11 |
Kazan
Rep Power: 2 |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 07:36 |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 16:26 |
interFoam (HELYX-OS) pressure boundary conditions | SFr | OpenFOAM Running, Solving & CFD | 8 | June 23, 2016 17:36 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 06:58 |
interFoam in parallel | gooya_kabir | OpenFOAM Running, Solving & CFD | 0 | December 9, 2013 06:09 |
