Mesh in a Two Phase Flow
Old   March 26, 2019, 10:59
Default Mesh in a Two Phase Flow
Marcos Vinícius Salles
SallesJlle is on a distinguished road
Hello folks, how are you?
I am new in openfoam and I need a little help. I need creat a 3D mesh with the cross sectional area like this one in the attached picture. I need to set up the blue part with water and the red part with air. Can you help me? If you know some tutorials or books that have a similar case to indicate, I will be very gracefull.
Best regards!
SallesJlle is offline   Reply With Quote
Old   April 3, 2019, 02:55
Geir Karlsen
gkarlsen is on a distinguished road
Best regards!
You can set the alpha field to the value you like by use of setFields. The dambreak tutorial uses this utility. You will need to change the cell sources from boxToCell to one of these:
https://github.com/OpenFOAM/OpenFOAM...ts/cellSources
gkarlsen is offline   Reply With Quote
mesh, openfoam, two phase flow
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
Mass flow rate of phase in post mat_cfd CFX 0 September 3, 2013 08:55
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
