Ningyi Li
Rep Power: 8 ![]() |
Hi, eveyone
I want to use the original solver in openfoam. So I copy the reactingFoam from the installed directory in my cluster /opt/bwhpc/common/cae/openfoam/v1706/OpenFOAM-v1706/applications/solvers/combustion/reactingFoam to my local folder. Then I change the reactingFoam.C to my_reactingFoam.C in my folder. I only change the content in the Make/files: my_reactingFoam.C EXE = $(FOAM_USER_APPBIN)/my_reactingFoam Finally, i run the wclean and wmake commands, but I got the same error after compiled: errors: cae/openfoam/v1706/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/my_reactingFoam.o -L/opt/bwhpc/common/cae/openfoam/v1706/OpenFOAM-v1706/platforms/linux64GccDPInt32Opt/lib \ -lfiniteVolume -lfvOptions -lmeshTools -lsampling -lturbulenceModels -lcompressibleTurbulenceModels -lreactionThermophysicalModels -lspecie -lcompressibleTransportModels -lfluidThermophysicalModels -lchemistryModel -lODE -lcombustionModels -lOpenFOAM -ldl \ -lm -o /home/kit/itt/qy5011/OpenFOAM/qy5011-v1706/platforms/linux64GccDPInt32Opt/bin/my_reactingFoam Make/linux64GccDPInt32Opt/my_reactingFoam.o: In function `Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::storeOldTimes() const': my_reactingFoam.C ![]() Make/linux64GccDPInt32Opt/my_reactingFoam.o: In function `Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>::storeOldTimes() const': my_reactingFoam.C ![]() Make/linux64GccDPInt32Opt/my_reactingFoam.o: In function `Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::storeOldTimes() const': my_reactingFoam.C ![]() Make/linux64GccDPInt32Opt/my_reactingFoam.o: In function `Foam::GeometricField<Foam::Vector<double>, Foam::fvsPatchField, Foam::surfaceMesh>::storeOldTimes() const': my_reactingFoam.C ![]() Make/linux64GccDPInt32Opt/my_reactingFoam.o ![]() collect2: error: ld returned 1 exit status I found the Foam::string::endsWith defined in the in the openfoam v1812 src/OpenFOAM/primitives/strings/string/string.CSo I include -lOpenFOAM in my Make/options, but it still does not work. gcc -v COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/pfs/data1/software_uc1/bwhpc/common/compiler/gnu/7.1.0/bin/../libexec/gcc/x86_64-pc-linux-gnu/7.1.0/lto-wrapper Target: x86_64-pc-linux-gnu Configured with: ../configure --prefix=/opt/bwhpc/common/compiler/gnu/7.1.0 --enable-languages=c,c++,lto,fortran,go --disable-multilib --with-tune=generic --with-system-zlib --enable-shared --with-ppl --enable-gnu-unique-object --enable-linker-build-id --with-gmp-lib=/home/hs/hs_hs/hs_doros/bwhpc-rpmbuild/BUILD/gcc-7.1.0/opt/bwhpc/common/compiler/gnu/7.1.0/lib64 --with-gmp-include=/home/hs/hs_hs/hs_doros/bwhpc-rpmbuild/BUILD/gcc-7.1.0/opt/bwhpc/common/compiler/gnu/7.1.0/include --with-mpfr=/home/hs/hs_hs/hs_doros/bwhpc-rpmbuild/BUILD/gcc-7.1.0/opt/bwhpc/common/compiler/gnu/7.1.0 --with-mpc-lib=/home/hs/hs_hs/hs_doros/bwhpc-rpmbuild/BUILD/gcc-7.1.0/opt/bwhpc/common/compiler/gnu/7.1.0/lib64 --with-isl=/home/hs/hs_hs/hs_doros/bwhpc-rpmbuild/BUILD/gcc-7.1.0/opt/bwhpc/common/compiler/gnu/7.1.0 Thread model: posix gcc version 7.1.0 (GCC) Could someone can help me to solve this problem? Thank you in advance. Best regards, Ningyi |
Tobias Holzmann
Rep Power: 51 ![]() ![]() ![]() |
you have a crazy text formatting. I am wondering what you are doing because you are mixing two different OpenFOAM versions (1706 and 1812). Furthermore, did you compile your foam source code or was it an installation from a package (the path /opt/... seems that it was an installation).
Keep foaming, Tobias Holzmann |
#3 | |
Ningyi Li
Hi, Tobi Thank you for your reply. And this problem was solved now. You are right. I atually mixed two different OpenFOAM version, which caused this problem, beacuase after I installed the v1812, the problem was solved automatically. Moreover, I installed the mpi/openmpi/3.1-gnu-4.8 for v1706, I guess this mpi version may be not suitable for OpenFOAM v1706, suitable for v1812. Thank you again. Best, Ningyi |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
