February 4, 2019, 06:31 |
Checkerboarding > SimpleFoam
Zander Meiring
Rep Power: 8 |
Good day!
I am investigating the possible cause and implication of checkerboarding pressure in my solution. I am using the simpleFoam solver for a 3d steady state solution using the k-omega sst turbulence model. At this point, my solution has iterated through 47500 times, and have reached the following residuals: Code:
smoothSolver: Solving for Ux, Initial residual = 3.52304e-06, Final residual = 1.75112e-10, No Iterations 9 smoothSolver: Solving for Uy, Initial residual = 1.29964e-05, Final residual = 7.31583e-10, No Iterations 9 smoothSolver: Solving for Uz, Initial residual = 9.49277e-06, Final residual = 9.39161e-10, No Iterations 8 GAMG: Solving for p, Initial residual = 0.00739052, Final residual = 7.33255e-06, No Iterations 49 time step continuity errors : sum local = 3.0622e-07, global = 1.03018e-09, cumulative = 1.84471e-05 smoothSolver: Solving for omega, Initial residual = 1.55815e-08, Final residual = 8.38819e-11, No Iterations 3 smoothSolver: Solving for k, Initial residual = 3.76601e-05, Final residual = 2.5968e-09, No Iterations 7 bounding k, min: -7.15622e-07 max: 186.885 average: 68.8195 my fvSchemes is as follows: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear corrected 1; } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U); div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,omega) Gauss upwind; div(phi,R) Gauss linear; div(R) Gauss linear; div(phi,nuTilda) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected 1; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "(p|Phi)" { solver GAMG; tolerance 1e-8; relTol 0.001; smoother DIC; nPreSweeps 1; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 3600; mergeLevels 1; maxIter 200; } "(U|k|epsilon|omega)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-10; relTol 0.0001; } "(U|k|epsilon|omega)Final" { $U; tolerance 1e-10; relTol 0; } } SIMPLE { nNonOrthogonalCorrectors 0; } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.6; "(epsilon|omega)" 0.6; } } cache { grad(U); } Is it more likely to be mesh, boundary or interpolation scheme dependent? If it is the interpolation scheme, what measured can be used to remedy this? To my understanding, turbulence modelling is first order accurate at best, and so going beyond upwind is not needed |
February 5, 2019, 13:05 |
Michael Alletto
Rep Power: 16 |
Is it a slip or no-slip wall? Is your outlet boundary far away enough it is consistent with your zero gradient B.C.?
February 6, 2019, 05:12 |
#3 | |
Zander Meiring
Rep Power: 8 |
It is a slip wall in this case, but I also see it occuring on non-slip walls. My outlet is very far from the rest of the domain. It's consistent in distance to literature on similar simulations, and far enough that the pressure difference over the second half of the domain is less than one pascal |
interFoam vs. simpleFoam channel flow comparison | DanM | OpenFOAM Running, Solving & CFD | 12 | January 31, 2020 15:26 |
Pressure drop over throttle disappears (simpleFoam --> pipe simulation) | highpressuretube | OpenFOAM Running, Solving & CFD | 18 | December 21, 2016 12:07 |
simpleFoam parallel solver & Fluent polyhedral mesh | Zlatko | OpenFOAM Running, Solving & CFD | 3 | September 26, 2014 06:53 |
BC -> k e simpleFoam | klio | OpenFOAM Running, Solving & CFD | 54 | July 3, 2013 10:45 |
simpleFoam crash -> How to solve | tH3f0rC3 | OpenFOAM | 4 | May 12, 2011 07:07 |
