Os
Rep Power: 9 ![]() |
Hello guys ,
I am making a 2D airfoil simulation using OpenFoam turbulence modele (k kl omega) once i launche my calculations using pimpleFoam it starts okk but than diverges for the k Kl and Omega . While for the time step continuity Error evrrything is Okk. 1/- is this related to my mesh or it is because of the solver options that i need to Change . 2/- also for my boundary conditions i ve followed those used in the openfoam tutorial in tut/incopressible/pimpleFoam/RAS/elipseKKlomega. 3/-for the kl value i only used a small value of 1e-5 ( is there a way to calculate it or the value i used is okk?) 4/-for the mesh i used it is combined of two types of mesh where i ve used mergemeshes and stitchmesh to get my final mesh thats why you find front1 front 2 back 1 and back2 And these are the boundary conditions i used Are Attached and also the fvSolution and fvSchemes . |
Zander Meiring
Rep Power: 8 ![]() |
Try first solving using k-omega sst, or Spalart Allmaras and set the residuals quite low
Questions about ReTheta & Gamma setup in airfoil calculation | kevin.pku | OpenFOAM | 2 | January 4, 2023 06:04 |
Compressible subsonic 2d airfoil investigation | happyFoamer | OpenFOAM Running, Solving & CFD | 0 | February 22, 2018 10:59 |
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge | TWaung | CFX | 2 | February 16, 2010 08:11 |
NACA 23020 airfoil drag and lift calculation. | Zmur | CFX | 2 | December 23, 2008 16:35 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
