Running a simple hydropower flow simulation with the use of an actuator disk |
Edward
Rep Power: 7 ![]() |
Hello OpenFoamers,
I want to model a small flow channel with a water turbine midway that does not have any impellers for reduced complexity. At the impeller location I want to have some sort of actuator disk in the domain where I can set the hydraulic power loss across the impeller to represent a pressure loss. Please let me know how I should approach this problem. Thanks, John |
Kevin Williams
Rep Power: 10 ![]() |
I also have a similar problem but couldn't find any info regarding power coefficients.
Edward
Sorry for being persistent but can anyone provide suggestions on where I can start.
Thank You in advance, John |
Problems while running Cold Flow simulation 3D/ requesting 2D gmtry and tutorial ICE | Excalibu2r | FLUENT | 0 | February 26, 2017 10:58 |
Wind Tunnel Flow Simulation Mass Flow BC Issue | ledelman | SU2 | 4 | August 3, 2014 18:38 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
Running a feedback control simulation of the flow around a cylinder | gasagna | OpenFOAM Running, Solving & CFD | 0 | July 16, 2014 10:03 |
Unsteady simulation of flow past wheel | Tom | FLUENT | 8 | January 18, 2006 10:54 |
