cellZone not taking all the cells inside
Old   January 16, 2019, 02:16
Default cellZone not taking all the cells inside
rahulksoni's Avatar
Rahul Kumar Soni
rahulksoni is on a distinguished road
Send a message via Skype™ to rahulksoni
Someone please please help to my query raised at cellZone not taking all the cells inside and quoted below.
Originally Posted by rahulksoni View Post
My case details can be found at Courant number issue at lower rpm in pimpleDyMFoam
i am using OpenFOAM-3.0.x. My case is very similar to the propeller tutorial of pimpleDyMFoam except for one change that is the different design of propeller. Obviously, the dimensions of innerCylinderSmall and other cylinders were updated according to the new design/dimension of the propeller. Moreover, it is a fluid-filled closed chamber now without any inlet and outlet.
The Courant number issue was resolved as per discussions stated in Courant number issue at lower rpm in pimpleDyMFoam
The simulation runs seamlessly after changes. Thereafter I wanted to define the whole simulation zone as a porous zone called porosity1. Therefore, following part was added to the file createInletOutletSets.topoSetDict
    // Load initial cellSet
        name    porosity1;
        type    cellSet;
        action  new;
        source  boxToCell;
        sourceInfo
            box (-0.1 0.0 -0.1) (0.1 0.18 0.1);
    // Setting cellZone
         name    porosity1;
         type    cellZoneSet;
         action  new;
         source  setToCellZone;
         sourceInfo
                 set porosity1;
The total number of cells in the system as stated by checkMesh is 577544. Part of checkMesh result is shown below:
Mesh stats
    faces:            1873121
    internal faces:   1704405
    cells:            577544
    faces per cell:   6.19438
    boundary patches: 8
    point zones:      0
    face zones:       1
    cell zones:       1
Here, I also want to show the output of topoSet command which clearly tells that all 577544 cells get included in the cellZone 'porosity':
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 3.0.x-ac3f6c67e02f
Exec   : topoSet -dict system/createInletOutletSets.topoSetDict
Date   : Jan 02 2019
Time   : 18:25:33
Host   : "MSLab02"
PID    : 15445
Case   : /media/mslab02/Elements/CFD/StirredMill/OpenFOAM/V11_V10_originalStirredMillRPM1000/V11_V10_originalStirredMillRPM1000
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Reading topoSetDict
Time = 0
    mesh not changed.
Created faceSet boundaryFaces
    Applying source patchToFace
    Adding all faces of patch outerCylinder ...
    Found matching patch outerCylinder with 4036 faces.
    faceSet boundaryFaces now size 4036
Created faceSet outletFaces
    Applying source faceToFace
    Adding all faces from faceSet boundaryFaces ...
    faceSet outletFaces now size 4036
Created faceSet inletFaces
    faceSet inletFaces now size 4036
Read set faceSet outletFaces with size 4036
    Applying source normalToFace
    normalToFace : Normalized vector to (0 -1 0)
    Adding faces according to normal being aligned with (0 -1 0) (to within 0.3) ...
    faceSet outletFaces now size 1440
Read set faceSet inletFaces with size 4036
    normalToFace : Normalized vector to (0 1 0)
    Adding faces according to normal being aligned with (0 1 0) (to within 0.3) ...
    faceSet inletFaces now size 0
Created cellSet porosity1
    Applying source boxToCell
    Adding cells with center within boxes 1((-0.1 0 -0.1) (0.1 0.18 0.1))
    cellSet porosity1 now size 577544
Created cellZoneSet porosity1
    Applying source setToCellZone
    Adding all cells from cellSet porosity1 ...
    cellZoneSet porosity1 now size 577544
End
In the end, I run the solver pimpleDyMFoam. Let's see the initial output in the log.pimpleDyMFoam (which gets repeated throughout the simulation):
Exec   : pimpleDyMFoam -parallel
Date   : Jan 02 2019
Time   : 18:30:05
Host   : "MSLab02"
PID    : 16340
nProcs : 4
Slaves :
3
"MSLab02.16341"
"MSLab02.16342"
"MSLab02.16343"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
Create time
Create mesh for time = 0
Selecting dynamicFvMesh solidBodyMotionFvMesh
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone innerCylinderSmall
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Reading field p
Reading field U
AMI: Creating addressing and weights between 31980 source faces and 31980 target faces
AMI: Patch source sum(weights) min/max/average = 0.864049, 1.06838, 0.950135
AMI: Patch target sum(weights) min/max/average = 0.777792, 1.00559, 0.942769
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
Reading/calculating face velocity Uf
No MRF models present
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options model type explicitPorositySource
    Source: porosity1
    - selecting cells using cellZone porosity1
    - selected 89136 cell(s) with volume 0.00272961
Porosity region porosity1:
    selecting model: DarcyForchheimer
    creating porous zone: porosity1
Courant Number mean: 0 max: 0
Starting time loop
Reading surface description:
    zNormal
    isoQ
    propeller
forces forces:
    Not including porosity effects
deltaT = 1.19904e-05
Time = 1.19904e-05
solidBodyMotionFunctions::rotatingMotion::transformation(): Time = 1.19904e-05 transformation: ((0 0 0) (1 (0 0.000629496 0)))
AMI: Patch source sum(weights) min/max/average = 0.890328, 1.11472, 0.980946
AMI: Patch target sum(weights) min/max/average = 0.813328, 1.06253, 0.973343
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.00347262, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.00361454, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.00357922, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00518406, No Iterations 5
time step continuity errors : sum local = 8.59148e-07, global = -1.54541e-10, cumulative = -1.54541e-10
PIMPLE: iteration 2
smoothSolver:  Solving for Ux, Initial residual = 0.030644, Final residual = 6.75332e-07, No Iterations 2
smoothSolver:  Solving for Uy, Initial residual = 0.0254633, Final residual = 5.55156e-07, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 0.030196, Final residual = 7.25131e-07, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.171561, Final residual = 1.61213e-06, No Iterations 50
time step continuity errors : sum local = 5.96149e-10, global = -4.95493e-11, cumulative = -2.0409e-10
smoothSolver:  Solving for epsilon, Initial residual = 0.00240751, Final residual = 4.53715e-08, No Iterations 2
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 6.08364e-07, No Iterations 3
ExecutionTime = 21.82 s  ClockTime = 28 s
forces forces output:
    sum of forces:
        pressure : (0.32169 -0.0611844 -0.31682)
        viscous  : (6.64668e-06 -2.1396e-07 -6.79721e-07)
        porous   : (0 0 0)
    sum of moments:
        pressure : (-0.556742 -0.54134 -0.344258)
        viscous  : (-1.27764e-05 -6.49338e-05 -8.20582e-06)
        porous   : (0 0 0)
Courant Number mean: 0.0219529 max: 0.173894
deltaT = 1.43712e-05
Time = 2.63616e-05
We can see only 89136 cells out of total 577544 cells get selected for cellZone porosity1. Can anyone explain why it is happening?
I tried to visualize these cellZones and found that in otal two cellZones get created 'porosity1' and 'innerCylinderSmall'. Total 577544 cells gets divided in these two cellZones. 89136 cells in 'porosity1' and rest in 'innerCylinderSmall'. The same is evident in constant/polyMesh/cellZones file.
I have made the visual comparison of complete mesh and the two cellZones as in the attached image.
I also know that the defined porosity conditions are working fine but only for the outer region. I have attached the simulation snapshot at the end of 1 second of two simulations, one with defined porosity (left) and another without porosity (right). One can see that the simulation without porosity (right) has continuous velocity field throughout the region. However, one with porosity (left) has discretely reduced velocity particulary in the discussed outer porous region.
Everything is good to go except one that why porosity1 region even after being defined for the whole region is leaving the cells contained in innerCylinderSmall region/cellZone.
Someone please explain.
Any help is greatly appreciable.
rahulksoni is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
[snappyHexMesh] snappyHexMesh can't create refimenet region clktp OpenFOAM Meshing & Mesh Conversion 3 February 27, 2022 10:26
[snappyHexMesh] SHM error: inside mesh not possible Naresh yathuru OpenFOAM Meshing & Mesh Conversion 1 January 11, 2017 00:58
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
