January 13, 2019, 09:23 |
blockMeshDict of airfoil in circular rotor
Sanket
Rep Power: 8 |
Hello CFD Online family
I am used to being familiar with OpenFOAM. I am making NACA0018 Airfoil in rotor but i got the error below: --> FOAM FATAL ERROR: Invalid arc definition - are the points co-linear? Denom =0 From function cylindricalCS arcEdge::calcAngle() in file curvedEdges/arcEdge.C at line 55. Could some please explain this error? It would be a great help. I attach my blockDictMesh file. convertToMeters 1; vertices ( // R circle front (-1.4148 -1.4148 0) //0 ( 1.4148 -1.4148 0) //1 ( 1.4148 1.4148 0) //2 (-1.4148 1.4148 0) //3 (0 0 0) //4 (0.1000 0.07024 0) //5 (0.1000 -0.07024 0) //6 (1 0.00189 0) //7 (1 -0.00189 0) //8 // R circle back (-1.4148 -1.4148 1) //9 ( 1.4148 -1.4148 1) //10 ( 1.4148 1.4148 1) //11 (-1.4148 1.4148 1) //12 (0 0 1) // 13 (0.1000 0.07024 1) //14 (0.1000 -0.07024 1) //15 (1 0.00189 1) //16 (1 -0.00189 1) //17 ); blocks ( hex (0 6 5 3 9 15 14 12) (10 10 1) simpleGrading (1 1 1) //0 hex (0 1 8 6 9 10 17 15) (10 10 1) simpleGrading (1 1 1) //1 hex (1 2 7 8 10 11 16 17) (10 10 1) simpleGrading (1 1 1) //2 hex (2 3 5 7 11 12 14 16) (10 10 1) simpleGrading (1 1 1) //3 ); edges ( spline 4 5 ( (0.0125 0.02841 0) (0.0250 0.03922 0) (0.0500 0.05332 0) (0.0750 0.06300 0) ) spline 5 7 ( (0.1500 0.08018 0) (0.2000 0.08606 0) (0.2500 0.08912 0) (0.3000 0.09003 0) (0.4000 0.08705 0) (0.5000 0.07941 0) (0.6000 0.06845 0) (0.7000 0.05496 0) (0.8000 0.03935 0) (0.9000 0.02172 0) (0.9500 0.01210 0) ) spline 4 6 ( (0.0125 -0.02841 0) (0.0250 -0.03922 0) (0.0500 -0.05332 0) (0.0750 -0.06300 0) ) spline 6 8 ( (0.1500 -0.08018 0) (0.2000 -0.08606 0) (0.2500 -0.08912 0) (0.3000 -0.09003 0) (0.4000 -0.08705 0) (0.5000 -0.07941 0) (0.6000 -0.06845 0) (0.7000 -0.05496 0) (0.8000 -0.03935 0) (0.9000 -0.02172 0) (0.9500 -0.01210 0) ) arc 7 8 (1 0 0) spline 13 14 ( (0.0125 0.02841 1) (0.0250 0.03922 1) (0.0500 0.05332 1) (0.0750 0.06300 1) ) spline 14 16 ( (0.1500 0.08018 1) (0.2000 0.08606 1) (0.2500 0.08912 1) (0.3000 0.09003 1) (0.4000 0.08705 1) (0.5000 0.07941 1) (0.6000 0.06845 1) (0.7000 0.05496 1) (0.8000 0.03935 1) (0.9000 0.02172 1) (0.9500 0.01210 1) ) spline 13 15 ( (0.0125 -0.02841 1) (0.0250 -0.03922 1) (0.0500 -0.05332 1) (0.0750 -0.06300 1) ) spline 15 17 ( (0.1500 -0.08018 1) (0.2000 -0.08606 1) (0.2500 -0.08912 1) (0.3000 -0.09003 1) (0.4000 -0.08705 1) (0.5000 -0.07941 1) (0.6000 -0.06845 1) (0.7000 -0.05496 1) (0.8000 -0.03935 1) (0.9000 -0.02172 1) (0.9500 -0.01210 1) ) arc 16 17 (1 0 1) arc 0 3 (-2 0 0) arc 3 2 (0 2 0) arc 2 1 (2 0 0) arc 1 0 (0-2 0) arc 9 12 (-2 0 1) arc 12 11 (0 2 1) arc 11 10 (2 0 1) arc 10 9 (0-2 1) ); boundary ( inlet { type patch; faces ( (0 3 12 9) ); } outlet { type patch; faces ( (1 10 2 11) ); } frontAndBack { type empty; faces ( (0 6 5 3) //front (0 1 8 6) (1 2 7 8) (2 3 5 7) (9 15 14 12) // back (9 10 17 15) (10 11 16 17) (11 12 14 16) (2 11 12 3) // top (0 9 10 1) // bottom ); } ); mergePatchPairs ( ); |
Wave Rotor simulation | popezmark | OpenFOAM | 8 | February 4, 2014 19:00 |
Contra rotating rotor simulation using mixing plane method | venkat_aero2007 | FLUENT | 1 | August 29, 2012 06:36 |
coordinates of an airfoil of stator and rotor blade | ghaithhabbal | Main CFD Forum | 0 | December 31, 2011 13:28 |
[GAMBIT] Meshing airfoil using .dat file problem | creggie | ANSYS Meshing & Geometry | 10 | June 27, 2010 20:24 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 19:36 |
