Using randomise field function for turbulent channel flow |
December 20, 2018, 05:54 |
SOURAV GANGULI
Rep Power: 8 |
Hi
I am using randomise field function to give random perturbation over mean velocity considering parabolic mean velocity profile initially. But instead of adding to the mean velocity profile and generating instantaneous velocity profile it comes as a seperate file Urandom instead of U in the 0 folder. I am using OPENFOAM V6 with gcc compiler 4:7.3.0. Can anyone kindly tell me is this bug or some mistake in the procedure?
December 26, 2018, 16:55 |
Fumiya Nozaki
Rep Power: 19 |
I think Urandom = U + random perturbations.
You can use the Urandom field as an initial velocity field by renaming it. Best regards, Fumiya
[Personal]
December 27, 2018, 01:16 |
SOURAV GANGULI
Rep Power: 8 |
Hi Fumiya,
Thanks for your suggestion.I will do the same. But can you tell me as the other field functions automatically updates after specified time step then why it won't able to? |
Randomise Field Function Object | MattiaC | OpenFOAM Programming & Development | 0 | September 29, 2017 05:40 |
Field function - Fully developed flow profile for a square micro channel | smorls | Main CFD Forum | 5 | April 9, 2015 12:01 |
Open Channel Flow | ElanMorin | FLUENT | 4 | February 25, 2015 17:26 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
