November 30, 2018, 04:26 |
DecomposeParDict with weightField
Morteza
Rep Power: 8 |
Dear foamers,
I have a question about using decomposeParDict for Eulerian-Lagrangian solvers. I am trying to assign more cores to the location of mesh where particles are concentrated. The following hint in decomposeParDict is adressing the solution to this issue: Use the volScalarField named here as a weight for each cell in the // decomposition. For example, use a particle population field to decompose // for a balanced number of particles in a lagrangian simulation. // weightField dsmcRhoNMean; I used alpha.water as a volScalarField here, but it did not work. Is there anybody with experience in using such a capability of decomposition in OpenFOAM? Thanks. |
February 3, 2022, 10:10 |
UOCFD
Rep Power: 5 |
I have same doubts, can decomposing be weighted by rhoEffLagrangian field??
decomposepardict, particle |
[snappyHexMesh] universal decomposeParDict | manuelffonseca | OpenFOAM Meshing & Mesh Conversion | 0 | March 31, 2017 08:36 |
Any example of manualCoeffs for decomposeParDict? | yuhai | OpenFOAM Running, Solving & CFD | 6 | July 21, 2015 10:51 |
Running OpenFOAM in parallel by enabling distributed in decomposeParDict | summer | OpenFOAM Pre-Processing | 0 | September 26, 2013 16:31 |
Skew factor of decomposeParDict | jms | OpenFOAM | 1 | May 29, 2013 12:12 |
Environment variable ($MPI_PROCS) in decomposeParDict | Pj. | OpenFOAM Running, Solving & CFD | 2 | April 8, 2013 02:38 |
