Use a turbulent solver with an uncertain turbulence flow |
November 27, 2018, 16:37 |
Nicola D'Ettole
Rep Power: 8 |
I'm new in opefoam. I want to determine the velocity field in an internal flow, but I need to know the speed to calculate the number of Re. The problem is that velocity changes at different points in the cavity, so the flow can be classified as turbulent (Re> 4000), transactional or laminar. If I use a turbolent solver such as simpleFam and the real flow is laminar / transactional, are the results reliable? are they more accurate with turbulent models ? Last edited by ing.nicola.dettole; November 28, 2018 at 04:54. |
November 28, 2018, 04:25 |
#2 | ||
Robert
Rep Power: 12 |
If you are unsure of whether or not your flow is laminar or turbulent, use a turbulence model to begin with. Want a "quick" solution to approach the simulation of the transition of trubulent to laminar flow? Quote:
*Quoted from: Turbulent and laminar conditions in one case, since you are dealing with a similar question.
If you liked my answer to your question, please consider leaving a "Like" in return |
November 28, 2018, 04:53 |
Nicola D'Ettole
Rep Power: 8 |
I will try quick approach.I have to do some proofs and tests i hope this help me to performe minimal number of tests.
I think that in the my range of inlet flow the problem is laminar for a flow of 1 m^3/h and turbulent for a flow of 10m^/h. Thank you. |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Is this understanding of turbulence models correct? | 3kha | Main CFD Forum | 3 | January 31, 2011 22:31 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 18:15 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 05:24 |
