Free surface Boundary Condition for dynamic mesh
Old   November 21, 2018, 02:38
Default Free surface Boundary Condition for dynamic mesh
Mitsuru Nishikawa
mit326 is on a distinguished road
Dear all,
I am trying single-phase free surface flow simulation by using dynamic mesh scheme.
I succeed to track interface and simulate free surface dynamics to some extent.
Now, I am wondering if I could set up boundary conditions for free surface.
(1) kinematics condition ((v-vf).n=0)
I learned symmetry conditions for velocity are similar to this condition.
But, in openFOAM, when B.C. for U is set to symmetryPlane,
pressure also necessarily is to be set as symmetryPlane (because mesh type is prescribed to be the same. slip condition is probably not suited since wall-normal velocity is zero)
If you know, Could you tell me alternative B.C. or how to implement it.
(2) dynamic condition
Because surface tension of my case is constant, normal force balance is just considered.
Therefore, I am considering that set-up of B.C. of pressure is just needed.
If you know or have tried implementation of such a case,
I would appreciate it if you could tell me.
Thank you in advance.
Best regards.
mit326 is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
