November 2, 2018, 10:29 |
Multicomponent Condensation
Rep Power: 9 |
Dear Foamers,
I am going to solve the multi-component condensation. I already wrote the code for multi-component mass transfer in the presence of K-value at the boundary. I am wondering if condensation is the same thing here which can model with differing K-value at different temperature and pressure. Besides that, I am wondering how someone would model the condensation of steam in the presence of other condensable gases. My main problem is that I cannot formulate the problem in terms of boundary conditions and source terms. Any brainstorming is appreciated . |
August 21, 2019, 06:53 |
Thomas Flint
Rep Power: 10 |
How are you getting on with your problem? I am solving a similar problem. In my case I use a volumetric dilation source term. This introduces an error though as you may have the case where in a cell one of the components is condensing and the other isnt, leading to a volume change in the non-condensing phase. I apply a correction step to account for this, but it's messy. |
August 21, 2019, 12:02 |
Rep Power: 9 |
Hi Thomas,
Thanks for your message. I am still working on that. Have you found any solution? Thanks, |
August 21, 2019, 12:51 |
Thomas Flint
Rep Power: 10 |
Yes,
You need to modify MULES and then add a dilation term. I’m currently finalising a manuscript on this. You should also check out the papers of Alex Rattner at Penn state on condensing and evaporating flows. Once you have modified mules for the state transitions you have to adjust the fluxes to maintain the volume consistency of the non boiling/condensing components ( I have t found a neat way to do this yet, so it’s very clunky for me at the moment) I’ll share my manuscript draft when I have it in a better state. |
August 27, 2019, 21:37 |
Rep Power: 9 |
Thanks Thomas. Let's say you have two components in your gaseous phase which are going to condense at different temperatures. So I am wondering how you are going to change their concentration in the gaseous phase.
November 8, 2020, 12:13 |
Multiphase condensation and evaporation
Thomas Flint
Rep Power: 10 |
If you are still interested in multiphase condensation, and/or evaporation, I have just had my paper on this subject published. You can find it here: https://www.nature.com/articles/s42005-020-00462-7 Please let me know if you have any questions. This framework is fully mass conservative. I realised after submission I should have included a plot showing the mass continuity equation is solved perfectly up to a tolerance of 10^-12. Ill show this in a future publication I知 sure. There is a paper on a silver called dropletsmoke++ that shows some of the mathematics you will need to get to my equations. All the best, Tom |
November 9, 2020, 01:05 |
Sumit Peh
Rep Power: 8 |
Hi Tom,
Congratulations, your paper is interesting. you seem experienced in OpenFOAM, could you guide me how to apply the mass transfer model in form of Kla to reactingTwoPhaseEulerFoam solver ? I found only a way to change mass transfer in empirical form. (Frossling on reactingTwophaseEulerFoam) Thanks in advanced |
November 9, 2020, 20:46 |
Expert in failure
Thomas Flint
Rep Power: 10 |
Thanks for the kind words. I don稚 know about being too experienced in openfoam. I知 pretty sure I have just tried all the ways to get it wrong by now.
I知 not familiar with that problem. I知 very busy at the moment, but if you post some links to some literature and the equations you are trying to solve I値l do my best to give you some pointers. You will have to add the mass transfer terms as explicit/implicit I知 MULES - normally written as Su or Sp in examples I have seen. The mass transfer rate of phase1 -> 2 should be equal and opposite of that from 2->1 to conserve the mass of the system. If there is a density change between the two phases you will have to add a dilation term in the pressure equation also. A really good start would be to look at interthermalphasechangefoam is SoftwareX by Nabil and Rattner (if my memory serves me correctly) I took a lot of inspiration from this work and the dropletsmoke++ publications. I hope this helps. If you list some references I値l try and help further but I really am very busy so can稚 promise anything. |
condensation, mass transfer, multicomponent mixture |
How accurate can CFX model condensation? | JuPa | CFX | 7 | January 20, 2019 18:17 |
Problem setting up Condensation | cwl | STAR-CCM+ | 2 | September 1, 2017 07:35 |
Boiling plus condensation in a closed domain | edmondlam | Fluent Multiphase | 0 | December 29, 2015 00:26 |
combustion radiation and condensation in cfx | siden | CFX | 1 | February 3, 2011 18:39 |
Multicomponent condensation | Daniel Foresto | CFX | 1 | February 5, 2007 11:28 |
