The number of points in the mesh seems to have changed
Old   October 29, 2018, 22:55
Default The number of points in the mesh seems to have changed
Motiur Rahman
Motiur is on a distinguished road
I run a case which have dynamic motion and AMR. I merged two libraries (motion lib and refinement llib) in Foam Extend 3.0. My case is stopped at 2nd iteration. After looking into the run file, it seems that both motion and refinement works. I got a error like -
" --> FOAM FATAL ERROR:
The number of points in the mesh seems to have changed.
In constant/polyMesh there are 402132 points; in the current mesh there are 497416 points.
From function sixDoFRigidBodyMotionSolver::curPoints() const
in file sixDoFRigidBodyMotionSolver/sixDoFRigidBodyMotionSolver.C at line 177.
FOAM exiting'
I think, the error comes due to mesh refinement. After each refinement it didn't overwrite the polyMesh file.
My question is, how can I overwrite polyMesh file in each iteration? If I need to recompile sixDoFRigidBodyMotionSolver.C , How I need to edit it?
FoamFile
version 2.0;
format ascii;
class dictionary;
object dynamicMeshDict;
dynamicFvMesh dynamicMotionSolverRefineFvMesh;
motionSolverLibs ("libsixDoFRigidBodyMotion.so");
solver sixDoFRigidBodyMotion;
sixDoFRigidBodyMotionCoeffs
patches (obstacle);
innerDistance 1.1;
outerDistance 1.3;
centreOfMass (0 0 0);
mass 2091.88;
momentOfInertia (1673.5 1673.5 1673.5);
rhoInf 1;
report on;
value uniform (0 0 0);
accelerationRelaxation 0.4;
solver
type Newmark;
constraints
zAxis
sixDoFRigidBodyMotionConstraint line;
direction (0 0 1);
yPlane
sixDoFRigidBodyMotionConstraint axis;
axis (0 1 0);
restraints
translationDamper
sixDoFRigidBodyMotionRestraint linearDamper;
coeff 8596;
rotationDamper
sixDoFRigidBodyMotionRestraint sphericalAngularDamper;
coeff 11586;
dynamicMotionSolverRefineFvMeshCoeffs
// How often to refine
refineInterval 1;
// Field to be refinement on
field alpha.water;
// Refine field inbetween lower..upper
lowerRefineLevel 0.01;
upperRefineLevel 0.99;
// If value < unrefineLevel unrefine
unrefineLevel 10;
// Have slower than 2:1 refinement
nBufferLayers 1;
// Refine cells only up to maxRefinement levels
maxRefinement 2;
// Stop refinement if maxCells reached
maxCells 35000000;
correctFluxes
(rhoPhi none)
(nHatf none)
(alphaPhi none)
(ghf none)
(phi U)
(phi_0 U_0)
(rhorUf phi)
(faceDiffusivity none)
(meshPhi none)
(weights none)
dumpLevel true;
Motiur is offline   Reply With Quote
Old   September 26, 2021, 04:11
Default Reply to Motiur
Trey
Trey is on a distinguished road
Hi, Motiur. Have you solved this problem? I have a similar problem recently.
If you can offer some pointers, I will be very grateful.
Trey is offline   Reply With Quote
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
