Cyclic Interface Error
Old   October 14, 2018, 06:57
Default Cyclic Interface Error
Steven
Whiteblue is on a distinguished road
Hi, I'm getting the following error when I use Cyclic Interface. I'm trying to use Cyclic Interface to model velocity jump(booster fan). The booster fan is located in a large room(warehouse) and is meant to help with circulation.
Thank you for your help in advance!
| \\ / O peration | Version: v1612+ |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
/* Windows port by SIMFLOW Technologies *\
Build : v1612+-37dd88baa8fd
Exec : C:/Program Files/simFlow/engine-1612+/bin/simpleFoam
Date : Oct 14 2018
Time : 02:36:49
Host : "A2551347"
PID : 33656
Case : C:/Users/samanh/simflow/100 E Ocean Garage/Test/Test
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
field p tolerance 0.0001
field epsilon tolerance 0.0001
field k tolerance 0.0001
field U tolerance 0.0001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
sigmaEps 1.3;
C2 1.92;
C3 -0.33;
sigmak 1;
Creating MRF zone list from MRFProperties
Creating finite volume options from "system/fvOptions"
Starting time loop
Time = 1
--> FOAM FATAL ERROR:
Not implemented
--> FOAM Warning :
From function void Foam::jumpCyclicFvPatchField<Type>::updateInterfac eMatrix(Foam::scalarField&, const scalarField&, const scalarField&, Foam::direction, Foam::UPstream::commsTypes) const [with Type = Foam::Vector<double>; Foam::scalarField = Foam::Field<double>; Foam::direction = unsigned char]
in file lnInclude/jumpCyclicFvPatchField.C at line 141.
FOAM aborting
Whiteblue is offline   Reply With Quote
Old   December 16, 2018, 19:47
Matt Houchin
HouchinM is on a distinguished road
I'm also having issue with jumpCyclic::updateInterfaceMatrix when I try to implement the swirlFanVelocity for a similar application (jet fan in a tunnel).
I'm assuming the issue is something to do with this function:
template<class Type>
void Foam::jumpCyclicFvPatchField<Type>::updateInterfaceMatrix
    scalarField& result,
    const scalarField& psiInternal,
    const scalarField& coeffs,
    const direction cmpt,
    const Pstream::commsTypes
) const
    NotImplemented;
My C++ skills are not too good so I'm not sure how to go about solving this issue. Has anyone else come across this problem?
HouchinM is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
