September 27, 2018, 16:09 |
Lagrangian particle face IDs wrongly printed
Rep Power: 10 |
I'm doing some Lagrangian particle tracking simulations for which I'm using icoUncoupledKinematicParcelFoam. When I look at the files generated within each time step folder at the end of the simulation, the 'positions' file has the position of the parcel and also the cell IDs. I want to change the code a bit to print out the face IDs instead of the cell IDs. I managed to do this by changing the particleIO.C file in src/lagrangian/basic/particle. Now, when I use > 1 processor, i.e. I run a parallel case, the reconstructed folders contain the 'positions' file in the Lagrangian folder but now instead of the face IDs being printed beside the particle positions, '-1' gets printed for all the particles. However, in the 'positions' file inside each processor folder, I can see the face IDs of particles being printed correctly. I don't know why the reconstructed case folder is not able to print these. I've attached my modified particleIO.C file below. Code:
#include "particle.H" #include "IOstreams.H" // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * // Foam::string Foam::particle::propertyList_ = Foam::particle::propertyList(); Foam::string Foam::particle::propertyTypes_ = Foam::particle::propertyTypes(); const std::size_t Foam::particle::sizeofPosition_ ( offsetof(particle, facei_) - offsetof(particle, position_) ); const std::size_t Foam::particle::sizeofFields ( sizeof(particle) - offsetof(particle, position_) ); // * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * // Foam::particle::particle(const polyMesh& mesh, Istream& is, bool readFields) : mesh_(mesh), position_(), celli_(-1), facei_(-1), stepFraction_(0.0), tetFacei_(-1), tetPti_(-1), origProc_(Pstream::myProcNo()), origId_(-1) { if (is.format() == IOstream::ASCII) { is >> position_ >> facei_; if (readFields) { is >> facei_ >> stepFraction_ >> tetFacei_ >> tetPti_ >> origProc_ >> origId_; } } else { if (readFields) { is.read(reinterpret_cast<char*>(&position_), sizeofFields); } else { is.read(reinterpret_cast<char*>(&position_), sizeofPosition_); } } // Check state of Istream is.check(FUNCTION_NAME); } void Foam::particle::writePosition(Ostream& os) const { if (os.format() == IOstream::ASCII) { os << position_ << token::SPACE << facei_ ; } else { os.write(reinterpret_cast<const char*>(&position_), sizeofPosition_); } // Check state of Ostream os.check(FUNCTION_NAME); } Foam::Ostream& Foam::operator<<(Ostream& os, const particle& p) { if (os.format() == IOstream::ASCII) { os << p.position_ << token::SPACE << p.celli_ << token::SPACE << p.facei_ << token::SPACE << p.stepFraction_ << token::SPACE << p.tetFacei_ << token::SPACE << p.tetPti_ << token::SPACE << p.origProc_ << token::SPACE << p.origId_; } else { os.write ( reinterpret_cast<const char*>(&p.position_), particle::sizeofFields ); } return os; } // ************************************************************************* // (Only a few particle positions and face IDs are shown below for brevity) Code:
( (-0.001918232865 -0.002251041706 0.004467126053) -1 (0.001497556868 -0.002574867247 0.003103300752) -1 (0.001515351194 -0.002588116818 4.202558253e-05) 146613 (-0.001183838869 -0.002734988904 0.003129143429) -1 (-0.00287581985 -0.0006375774439 0.00465495688) -1 (0.0008197242898 -0.002883032753 0.0002544101809) 142108 (-0.002801806174 -0.0009609295494 0.003555561927) -1 (-0.002827043845 -0.0009907898813 9.971039645e-05) 142068 (-0.0004006887624 -0.002950641738 0.00333011665) -1 (-0.001155982476 -0.002762901972 0.001563768784) 145565 (-0.00209560257 -0.002098639602 0.004079087052) -1 (0.001702999671 -0.002467776191 9.921843668e-05) 142113 Code:
( (0.001503063296 -0.002432560028 0.009707915638) -1 (-0.001488287737 -0.002425862592 0.01028831296) -1 (-0.001613665466 -0.002351394638 0.01007192092) -1 (0.002273814785 -0.001745515031 0.009180543596) -1 (0.0006383612319 -0.002784751294 0.01002237924) -1 (0.002282777511 -0.001734923566 0.009138315696) -1 (0.002224614027 -0.001807140708 0.009203291626) -1 (0.0006227818597 -0.002791883515 0.009895327087) -1 (0.001862071026 -0.002166846251 0.009715677211) -1 (0.001459660893 -0.002460366998 0.009635536246) -1 (0.001888048648 -0.002144299877 0.009675871161) -1 (0.001871450245 -0.002160270873 0.009639408655) -1 (0.002254906134 -0.001772654796 0.009098633124) -1 (0.00154276372 -0.00241127332 0.009628450194) -1 (-0.001597582009 -0.002364443428 0.0100017453) -1 (0.001445232902 -0.002470776606 0.00957249016) -1 (-0.001493946214 -0.002425353115 0.01014971087) -1 (-0.001745678363 -0.002248147321 0.01035737724) -1 (0.001332290771 -0.002531094927 0.009757621791) -1 (-0.0008148733303 -0.002732127004 0.01022249142) -1 (-0.001762640206 -0.002234234694 0.01037401675) -1 (0.001750882135 -0.002261121501 0.009598710578) -1 (0.001576125126 -0.002389037127 0.009674199296) -1 (0.0004683611948 -0.002815714577 0.01005009407) -1 (5.060516259e-05 -0.002850537259 0.01025520226) -1 (-0.002772284988 0.0006477009081 0.009738074612) -1 Any help is greatly appreciated. Best, Scram_1 |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
[swak4Foam] Validation of swak4Foam for lagrangian particle tracking | nero235 | OpenFOAM Community Contributions | 13 | March 28, 2017 05:45 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
