September 27, 2018, 01:21 |
Adjust write interval for function output
hello foamers
I am running unsteady simulation and output some surface (isosurface of pressure with k,U) with setting functions in controlDict. I set the output as adjustableRuntime in the function with writeInterval with value say 0.1sec, I am trying to change the value to 0.05. But it doesn’t work. I already set the runTimeModifable to yes in the controlDict so that I can change output interval for fields and Co number. Can anybody helps on the that? Yours Wei |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 14:06 |
Write interval not in exact number | cwang5 | OpenFOAM Bugs | 8 | August 31, 2018 14:26 |
Execution time problem after first write interval | sean_mcintyre | OpenFOAM Running, Solving & CFD | 3 | July 28, 2008 09:46 |
[Other] Output Format of MetaMesh | t42 | OpenFOAM Meshing & Mesh Conversion | 0 | August 3, 2007 05:28 |
advanced output | huwei | CFX | 1 | March 21, 2001 15:43 |
