Adriana Ferreira
Rep Power: 7 ![]() |
Dear all,
There is any way to obtain cross section mean values in OpenFOAM as a function of the axis? In my simulation, I have a 2D channel (length in x-direction and radius in the y-direction) and I want to obtain the concentration mean value for the channel cross section as a function of x. Sample Dict give me the concentration in the position where the line is defined instead of the mean value. For the Average Field, I have to define the patch where I want to obtain the values and run the simulation to obtain the mean concentration (as a function of time) in a specific patch. I can use this option once I can fix at which time I want the data but for that, it has to be possible to define instead of the patch an x position and run it after the simulation had run. Is there possible? I want the values, for exemple, from 0.1x in 0.1x over channel lenght. Can you help me? Many thanks, Adriana |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
flow in a nozzle with two narrowed cross section | whitecat | FLUENT | 0 | November 17, 2014 09:00 |
Cross section and surface area factor | Fabiana | CFX | 0 | January 9, 2006 23:51 |
