September 22, 2018, 06:23 |
The compile error
TaoChen
Rep Power: 7 |
Hi guys:
When I copy the combustion/rhoReactingFoam code to the run and compile it using command wmake, there is a error: could not open file ../../../compressible/rhoPimpleFoam/pcEqn.H for source file rhoReactingFoam.C due to No such file or directory. How could I fix it? Thanks very much! |
September 24, 2018, 04:42 |
Tobias Holzmann
Rep Power: 51 |
As the error states, the application respectively the compiler searches for a files that is needed (I guess Make/options) with an relative path. Correct the path and you are happy.
could not open file ../../../compressible/rhoPimpleFoam/pcEqn.H for source file rhoReactingFoam.C due to No such file or directory. Code:
I cannot find the file "../../../compressible/rhoPimpleFoam/pcEqn.H" from the actual path (pwd) Please tell me where to find it
Keep foaming, Tobias Holzmann |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
