sprayFoam droplet-wall interaction Heat Transfer Problem |
September 21, 2018, 07:19 |
Sagar
Rep Power: 9 |
I am trying to simulate spray mist cooling of hot plate which is at constant temperature 1073K. Injected water droplet is at 303K and surrounding air is also at 303K. I am using sprayFoam to simulate this case. I have used following thermal spray models with coneNozzleInjection is used. heatTransferModel --> RanzMarshall phaseChangeModel --> liquidEvaporationBoil atomizationModel --> LISA Radiation is off. Now, Problem is when water droplets hits the hot plate(wall), they should be heated up. But in current case setup, temperature of droplets decreased by 4 to 5 degree instead of heated up. I can not understand why it happens? I am very close. can anybody help? I am attaching configuration and droplet temperature. |
Evaporation-Condensation in a porous zone (Heat transfer problem) | maximilian-1 | Fluent Multiphase | 1 | August 22, 2018 09:42 |
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? | MaxHeat | FLUENT | 4 | September 14, 2017 10:44 |
surface heat transfer coeff of wall flux | rsa | FLUENT | 0 | June 1, 2016 09:40 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
