Wrong Results with PimpleFoam
Old   September 2, 2018, 08:53
Default Wrong Results with PimpleFoam
Egalov is on a distinguished road
Dear Foamers,
I've been busy simulating a spherical particle in a cubic domain with pimpleFoam for quite a while lately. I tried with different mesh both structured using blockMesh and unstructured using SHM. In all the cases the solution for the pressure field is far from physical sense. The Geometry, the grid and the boundary conditions are all symmetrical as explained below:
0- Laminar (stokes flow).
1- sphere is located in the center of the box.
2- top wall in z direction is moving with a constant velocity in x direction.
3- front and back walls (\pmy) are frictionless (slip B.C.)
4- Bottom wall is frictional (noSlip B.C.)
5- Particle interface is frictional wall (noSlip B.C.)
Problem:
Given all this, I expected to get a symmetrical pressure distribution along y direction as well as higher order of pressure and viscous force on particle in z direction compared to y which are not the case.
Attachments is my boundary condition and a screenshot of mesh.
Any help on this problem is appreciated.
File Type: png Screenshot from 2018-09-02 13-45-51.png (14.5 KB, 12 views)
File Type: png Screenshot from 2018-09-02 13-46-33.png (33.7 KB, 10 views)
Egalov is offline   Reply With Quote
pimplefoam, pressure distribution
Problem: Very long "write" time (~2h-3h) for results and transient results Shawn_A CFX 16 April 12, 2016 21:49
wrong results after use UDF turbulent viscosity lehoanganh07 Fluent UDF and Scheme Programming 0 July 21, 2014 12:12
porous media turbulent model P-dL, I get the different results? is the model wrong? hitchenxue FLUENT 0 July 13, 2014 06:57
Comparing Air numerical results with water experimental results cristian2009es Main CFD Forum 1 July 2, 2014 19:11
I got complete different results for pisofoam and pimplefoam? lakeat OpenFOAM Running, Solving & CFD 6 December 27, 2012 05:25
