August 31, 2018, 19:38 |
Changing wave theories in the tutorials
Hillary Kiptoo
Rep Power: 8 |
Hi Niels,
Thanks for an excellent waves2Foam toolbox. I have been trying to understand the waveflume tutorial so that I can implement it in my case on Oscillating water column. In this regard my case is best implementable on stokesSecond order theory. Unfortunately, I seem not to be getting the idea of changing it to fit my case as I am getting this message when I run the edited waveflume tutorial. "Reading g Reading waveProperties Constructing: stokesFirstProperties (Used by another wave theory) Constructing: stokesSecondProperties Constructing: potentialCurrentProperties End" I am not quite sure if this is correct or there is a problem and the case is still running on the stokesFirstProperties. Kind regards, larry |
September 6, 2018, 18:16 |
Changing wave theories from the tutorials
Hillary Kiptoo
Rep Power: 8 |
Who can help me get an idea on how to implement wave theories on waves2Foam?
September 28, 2018, 05:28 |
ON the use of waves2Foam other wave theories
zhongzhong
Rep Power: 8 |
Hello,Excuse me,i want to ask have you solved this problem? i also met it now
if you solved it,can you tell me? Thank you very much |
October 2, 2018, 03:47 |
#4 | |
Hillary Kiptoo
Rep Power: 8 |
Thanks Larry K. |
October 2, 2018, 06:13 |
on the use of waves2Foam other wave theories
zhongzhong
Rep Power: 8 |
Thank you very much for your reply in your busy schedule.i seem to understand a lot after looking at the websites and materials you provided.Thank you very much.i wish you a convergence.:d
waves2foam |
Linear wave force on a cylinder | Pumbam | CFX | 1 | July 16, 2017 03:01 |
[waves2Foam] Wave damped totally in about 5 meters after wave maker, after making changes to case | mmbeik | OpenFOAM Community Contributions | 3 | August 18, 2015 06:56 |
IHFOAM - Wave generation with moving boundaries | Phicau | OpenFOAM Verification & Validation | 0 | May 18, 2015 05:53 |
Deep Water Wave Generation Problems | zx9cp | CFX | 4 | June 16, 2013 07:23 |
Changing the geometry BC and IC of tutorials | hyunchang | OpenFOAM Running, Solving & CFD | 0 | September 11, 2007 13:35 |
