field dimesions
Old   August 31, 2018, 12:50
Question field dimesions
Roberto
RobertoN is on a distinguished road
Dear All,
I need to obtain field dimensions from a field or from a dimensionedScalar.
Are there a method to obtaint the dimensions vector?
For example:
volScalarField field1(...);
dimesionedScalar var2(...);
vector dim1 = field1.dimensions();
vector dim2 = var2.dimensions();
I didn't find a way with google.
Thank you in advance.
RobertoN is offline   Reply With Quote
Old   August 31, 2018, 19:43
clapointe is on a distinguished road
What do you need it for? A quick search of the code for something.dimesions() returns a lot of hits, so an easy way to check will be :
Info << "Dimensions : " << s.dimensions() << nl <<endl;
If you want to be able to use it, you can create a dummy variable (for eg a scalar) I think like
dimensionedScalar(tmp,s.dimensions(),SMALL)
Caelan
clapointe is offline   Reply With Quote
dimensions, openfoam 4.0 extend
potential flows, helmholtz decomposition and other stuffs pigna Main CFD Forum 1 October 26, 2017 09:34
[General] How to create an additional vector with {Field 4, Field 5, Field 6} Bombacar ParaView 1 August 15, 2015 19:05
New BoundaryCondition: how to modify a single component of a field? look86 OpenFOAM Programming & Development 4 August 28, 2012 17:48
How to define a field on a patch Aleksey_R OpenFOAM Programming & Development 1 July 9, 2012 12:23
Demagnetization field jan0385 ANSYS 0 April 12, 2012 10:09
