Problem with wake pressure for unsteady flow around circular cylinder
Old   August 27, 2018, 07:51
Default Problem with wake pressure for unsteady flow around circular cylinder
Bazinga is on a distinguished road
I am trying to compute the unsteady flow around a circular cylinder using an URANS approach and foam extend 4.0. The problem is that I get some weird pressure regions in the wake very close to the surface of the cylinder as shown in the attached figure. I already performed multiple simulations with the below-mentioned setup with different rectangular shapes without any similar issues. For the rectangular shapes, I also used this setup for free and forced oscillations of the cylinder.
It is a low-Re approach using the k-omega SST model only using a wall function for omega. I keep the max Courant Number < 1 and the average y+ value is ~0.5. In time I discretize using Crank Nicolson and 2nd order upwind for the divergence schemes. The Reynolds number is somewhere around 50.000.
I already played around with 2nd order discretization schemes and the solution procedure. Tested with OpenFOAM 5 and got similar results. Also, the problem occurs on different meshes, however, the area of the high suction behind the cylinder gets a bit smaller with refined mesh.
The 0, constant and system directories of the simulation and some results can be found here:
https://drive.google.com/open?id=1t3...8xOhxXI4Z_PNtm
Wondering if anyone got similar problems or can point me in the right direction. Again, what bothers me a bit is that for various rectangular shapes I never got similar problems.
Bazinga is offline   Reply With Quote
Old   August 27, 2018, 08:04
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
> it is a low-Re approach ... Reynolds number is somewhere around 50.000.
50000 is not a low Reynolds number. It is quite high instead. I recommend to read the results of CFDing with Re=3900 and the problems whick ocured at this much lower Re:
Detached–eddy simulations of the flow over a cylinder at Re = 3900 using OpenFOAM, Valerio D’Alessandro, Sergio Montelpare, Renato Ricci
https://www.researchgate.net/publica...using_OpenFOAM
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   August 27, 2018, 08:13
Dear Piu58,
Yes, indeed 50000 is not a low Reynolds number! With low-Re approach I was referring to the modeling at the wall (see for example: https://www.cfd-online.com/Wiki/Two_...bulence_models).
Thanks for the reference, I will check it out.
Accuracy Problem with Flow over 2D cylinder at Transcritical Reynolds Number zx9cp CFX 6 July 14, 2016 06:51
FLUENT, flow past a circular cylinder Paul Reichl Main CFD Forum 16 December 8, 2012 16:21
Flow not moving - Supersonic/Initial Pressure problem? shankara.2 FLUENT 0 June 9, 2009 21:49
base pressure for circular cylinder fpz Main CFD Forum 7 June 20, 2005 22:30
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
