Nusselt Number
Old   August 19, 2018, 21:19
Exclamation Nusselt Number
Bruno Paes Fragoso
brunop96 is on a distinguished road
I'm facing a problem with nusseltcalc compilation. I have modified the tool wallheatflux (OpenFoam Version 4.1) and I don't know how to solve the problem bellow. Maybe I have done something wrong, but I can't identify ( I new in C++). Thanks for your help!!!
Making dependency list for source file NusseltCalc.C
g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam4/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/openfoam4/src/TurbulenceModels/compressible/lnInclude -I/opt/openfoam4/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam4/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/openfoam4/src/transportModels/compressible/lnInclude -I/opt/openfoam4/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam4/src/thermophysicalModels/solidThermo/lnInclude -I/opt/openfoam4/src/finiteVolume/lnInclude -I/opt/openfoam4/src/meshTools/lnInclude -IlnInclude -I. -I/opt/openfoam4/src/OpenFOAM/lnInclude -I/opt/openfoam4/src/OSspecific/POSIX/lnInclude -fPIC -c NusseltCalc.C -o Make/linux64GccDPInt32Opt/NusseltCalc.o
NusseltCalc.C: In function ‘int main(int, char**)’:
NusseltCalc.C:169:49: error: passing ‘const Foam::fvPatchField<double>’ as ‘this’ argument discards qualifiers [-fpermissive]
NusseltNumber.boundaryField()[patchi] = length*patchHeatFlux[patchi]/
In file included from /opt/openfoam4/src/finiteVolume/lnInclude/fvPatchField.H:592:0,
from /opt/openfoam4/src/finiteVolume/lnInclude/volFields.H:40,
from /opt/openfoam4/src/finiteVolume/lnInclude/surfaceInterpolationScheme.C:27,
from /opt/openfoam4/src/finiteVolume/lnInclude/surfaceInterpolationScheme.H:304,
from /opt/openfoam4/src/finiteVolume/lnInclude/surfaceInterpolate.H:41,
from /opt/openfoam4/src/finiteVolume/lnInclude/fvc.H:39,
from /opt/openfoam4/src/finiteVolume/lnInclude/fvCFD.H:8,
from NusseltCalc.C:34:
/opt/openfoam4/src/finiteVolume/lnInclude/fvPatchField.C:395:6: note: in call to ‘void Foam::fvPatchField<Type>:perator=(const Foam::UList<T>&) [with Type = double]’
/opt/openfoam4/wmake/rules/General/transform:8: recipe for target 'Make/linux64GccDPInt32Opt/NusseltCalc.o' failed
make: *** [Make/linux64GccDPInt32Opt/NusseltCalc.o] Error 1
brunop96 is offline   Reply With Quote
Nusselt number calculation in Fluent Sharadkumar Yeri FLUENT 52 May 29, 2019 07:29
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
