August 19, 2018, 19:40 |
Best FOAM Workflow
E
Rep Power: 8 |
I am new and the problem I'm running into is that there seems to be no one optimal workflow for OF.
Seems like everyone's using a mixture of FreeCAD, Sketchup, Salome, Salome Meca, Gmsh, Helyx OS, OnShape, Blender and so forth My question is What is the optimal free software/workflow for OpenFoam? Is Salome or Blender powerful enough to create complex CAD or should I use OnShape then Salome to watertight geometry then move to Gmsh for better mesh. Should I start my case with free version of Helyx then edit it from there. guess I'm looking for the best way to do this so I don't waste time fiddling with all these different software's. |
August 27, 2018, 10:42 |
InsightCAE - Open Source Project for Workflow Automation InsightCAE - Open Source Project for Workflow Automation DICE - OpenFOAM GUI project alternative mesher cfMesh library can be downloaded from: https://sourceforge.net/projects/cfmesh/ |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 03:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
