August 7, 2018, 13:54 |
KinematicParcel fvc::curl(U)
Joaquín Neira
Rep Power: 9 |
I'm trying to set the vorticity of the fluid in a similar way than the velocity or density in the KinematicParcel class: File KinematicParcelTrackingDataI.H: Code:
template<class ParcelType> template<class CloudType> inline Foam::KinematicParcel<ParcelType>::TrackingData<CloudType>::TrackingData ( CloudType& cloud, trackPart part ) : ParcelType::template TrackingData<CloudType>(cloud), rhoInterp_ ( interpolation<scalar>::New ( cloud.solution().interpolationSchemes(), cloud.rho() ) ), UInterp_ ( interpolation<vector>::New ( cloud.solution().interpolationSchemes(), cloud.U() ) ), muInterp_ ( interpolation<scalar>::New ( cloud.solution().interpolationSchemes(), cloud.mu() ) ), curlUInterp_ ( interpolation<vector>::New ( cloud.solution().interpolationSchemes(), fvc::curl(cloud.U()) ).ptr() ), g_(cloud.g().value()), part_(part) {} Code:
template<class ParcelType> template<class TrackData> void Foam::KinematicParcel<ParcelType>::setCellValues ( TrackData& td, const scalar dt, const label celli ) { tetIndices tetIs = this->currentTetIndices(); rhoc_ = td.rhoInterp().interpolate(this->coordinates(), tetIs); if (rhoc_ < td.cloud().constProps().rhoMin()) { if (debug) { WarningInFunction << "Limiting observed density in cell " << celli << " to " << td.cloud().constProps().rhoMin() << nl << endl; } rhoc_ = td.cloud().constProps().rhoMin(); } Uc_ = td.UInterp().interpolate(this->coordinates(), tetIs); muc_ = td.muInterp().interpolate(this->coordinates(), tetIs); curlUc_ = td.curlUInterp().interpolate(this->coordinates(), tetIs); // Apply dispersion components to carrier phase velocity Uc_ = td.cloud().dispersion().update ( dt, celli, U_, Uc_, UTurb_, tTurb_ ); } Code:
[1] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [1] #1 Foam::sigSegv::sigHandler(int) at ??:? [1] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::interpolationCell<Foam::Vector<double> >::interpolate(Foam::Vector<double> const&, int, int) const at ??:? [1] #4 Foam::interpolationCell<Foam::Vector<double> >::interpolate(Foam::Barycentric<double> const&, Foam::tetIndices const&, int) const at ??:? |
lagrangian, lpt, vorticity |
Dealing with Lagrangian Library | omid20110 | OpenFOAM Programming & Development | 10 | June 10, 2018 11:12 |
two-way coupling with KinematicParcel class | jiejie | OpenFOAM Running, Solving & CFD | 2 | April 26, 2015 23:32 |
possible bug in KinematicParcel | guanghaowu | OpenFOAM Bugs | 0 | April 19, 2011 05:20 |
Segmentation Fault when using class based on KinematicParcel in parallel | gschaider | OpenFOAM Bugs | 1 | August 18, 2008 07:18 |
