How can a boundary read data from file while running a case |
Jarvis
Rep Power: 13 ![]() |
Hello foamers:
I'm trying to compile a new boundary to auto-update based on a value calculated from the main program. This value can be write to a text named "calculated" in constant file. I tried to use IOdictionary in my boundary, and try to register "calculated" in runTime.constant(), but runTime was not declared in the boundary. So how can the boundary read this data from a case file? Could you give me some advice? Thank you! |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
