To continue from latestTime of a previous serial run in parallel |
July 26, 2018, 09:00 |
So Anon
Rep Power: 12 |
When one runs a serial simulation he only gets temporal directories. But parallel run generates processor directories and reconstructs them into individual temporal directories.
My question is; say, after running a single processor simulation up to t=100 (or if I delete processor directories after a parallel run followed by a reconstruction and only temporal directories are left), is it possible to deconstruct those temporal directories into processors to continue from t=100 with a parallel run? |
July 26, 2018, 12:02 |
Taher Chegini
Rep Power: 12 |
A clean approach would be to create a copy of the case with addition of a decomeParDict and mapFieldsDict files. Then use the mapFields utility to map the fields as initial condition for the original case. Here's how I usually do this:
latest=$(foamListTimes -latestTime -case relative/path/to/original/case) mapFields -sourceTime $latest -consistent relative/path/to/original/case |
July 26, 2018, 14:01 |
Joachim Herb
Rep Power: 22 |
Have you tried running decomposePar after the serial run in the same case directory? (perhaps you need to use the option -latestTimestep or -lastestTime). This should create the processor directories with the 100 s timestep split up.
[Salome] Salome import "Cannot find file "points" in directory..." | mismichael | OpenFOAM Meshing & Mesh Conversion | 6 | June 24, 2024 03:17 |
MPI error in parallel application | usv001 | OpenFOAM Programming & Development | 2 | September 14, 2017 11:30 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
The results difference between parallel and serial run. | Hkp | OpenFOAM Running, Solving & CFD | 2 | April 17, 2014 02:26 |
