Modification of Thermophysical model in foam-ext
Old   July 25, 2018, 01:51
Default Modification of Thermophysical model in foam-ext
Ramana
svramana is on a distinguished road
Hello everyone,
I'm trying to simulate a Gas Turbine Stage using foam-ext using sonicDyMFoam solver. There is no tutorial for this in foam-ext, so I setup case myself by taking help of other tutorial. The setup is fine but problem is with 'thermophysicalPropertis'. Available model is ' ePsiThermo ' but I want to use ' hPsiThermo ' as turbine simulation should be based on enthalpy rather than internal energy.
When I'm using ePsiThermo simulation is running but when I'm using hPsiThermo I'm getting Following error
selecting thermodynamics package hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
--> FOAM FATAL ERROR:
Not implemented
From function basicThermo::e()
in file basicThermo/basicThermo.C at line 354.
FOAM aborting
Aborted (core dumped)
So I tried to modify createFields.H file. Then I compiled the file using wmake command I got warning like
In file included from sonicDyMFoam.C:63:0:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:10:21: warning: unused variable ‘h’ [-Wunused-variable]
volScalarField& h = thermo.h(); //newwly added
It mean I'm missing something but I don't know what. Can anyone help me on how to modify creatField.H, hEqn.H and sonicDyMFoam.C files or any other changes requires to make.
svramana is offline   Reply With Quote
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
conjugateHeatFoam: regionCoupling boundary in foam 3.0 ext ahmmedshakil OpenFOAM Programming & Development 0 September 27, 2014 10:26
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
