July 20, 2018, 06:07 |
Sprayfoam Jet diverges
Jan
Rep Power: 8 |
Hello guys, and thanks already for the upcoming help. I'm trying to do a Simulation of a spray flame with the Sprayfoam solver. To get a better start at the sprayFoam solver I started the same case in compressible mapped it to incompressible, simulated it again and mapped it to the sprayFoam solver. Till there everything worked fine, and i had not any convergence Problems. The geometry is a Wedge of a Sprayjet.
As soon as I started to simulate it in sprayFoam I'm gettting huge convergence problems. The residuals look like this: I tried to lower the relaxation factors, but even if I'm setting them far smaller, the U_z component is still fluctuating completely. Normally it should be a convergent "pype-flow", since I'm not initiating any parcels into the flow right now. Maybe someone here knows how to solve the convergence problem? I attached the fvSolution fvSchemes and the Checkmesh.log in a zip file. Thanks in advance Jan Files.tar.gz |
August 10, 2018, 10:21 |
Jan
Rep Power: 8 |
I figured the misstake out by myself, i used an inlet velocity of constant 36 m/s, somehow this wasn't as accurate as doing it with a constant inlet-mass. This fixed the problem.
divergence, divergent, openfoam, sprayfoam |
"Hand" calculation jet fan in the garage | mageno | Main CFD Forum | 3 | August 7, 2021 20:09 |
2D Plane Jet Fluent Solution | doug | Main CFD Forum | 11 | February 4, 2019 10:34 |
Jet in cross-flow using sprayFoam | vishal_s | OpenFOAM Running, Solving & CFD | 9 | April 6, 2018 01:18 |
sprayFoam crashes | lukasfischer | OpenFOAM Running, Solving & CFD | 3 | July 14, 2013 12:08 |
Jet in Supersonic Crossflow, controlling mass flow rate | ChrisA | OpenFOAM Running, Solving & CFD | 3 | November 13, 2012 19:20 |
