Creating an output file
Old   June 29, 2018, 07:17
Exclamation Creating an output file
Davide
Lighto is on a distinguished road
Hello everyone.
I'm very new to CFD enviroment and OpenFOAM software. I've managed to implement a lagrangian particle tracker inside pimpleFoam (I don't know if I can post here the reference pdf). Now I need to create an output file just like the one for velocity, pressure etc. but for the shear stress on particles, i.e. I need to output first order derivatives of u1,u2,u3 in x1,x2,x3, and then calculate the scalar stress:
\sigma = \frac{1}{\sqrt{3}}\sqrt{\tau_{11}^2+\tau_{22}^2+\tau_{33}^2-\tau_{11}\tau_{22}-\tau_{22}\tau_{33}-\tau_{33}\tau_{11}+3(\tau_{12}^2+\tau_{23}^2+\tau_{31}^2)}
where \tau_{ij} = \mu (\frac{\partial{u_i}}{\partial{x_j}}+\frac{\partial{u_j}}{\partial{x_i}})
This last part I think is easier once I understood how to output the spatial derivatives of the particles' velocities.
How can I implement this in OpenFOAM and in which file of the solver?
Thanks for your help.
Davide
Lighto is offline   Reply With Quote
Old   June 30, 2018, 12:07
Davide
I've read so many topics in these 24 hours but I didn't managed to solve my problem
However I have done a small progress, that I post here.
In the createFields.H file in the solver folder I've added the following lines to output the gradient of the vector field U (named DUDX):
volTensorField DUDX
    IOobject
        "DUDX",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::AUTO_WRITE
    mesh,
    //assign dim of tensor and inizialize it to zero
    dimensionedTensor("DUDX", dimVelocity/dimLength, tensor::zero)
and update it at every time step in the solver.C file, after the velocity corrector loop:
while (runTime.run())
        // --- Pressure-velocity PIMPLE corrector loop
        DUDX = fvc::grad(U);
(Note: i'm using a pimple solver with lagrangian particle tracking.)
This should output the gradient of the velocity as a tensor of 9 components du1/dx1, du2/dx1, etc. in the whole domain, but I want it only for the particles (so gradient of U of the particles, not U of the fluid).
derivatives, openfoam 4.0 extend, output, output file, stress
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
