postProcess -list : command not found OpenFOAM extend 4
Old   June 23, 2018, 10:00
Unhappy postProcess -list : command not found OpenFOAM extend 4
Os
losiola is on a distinguished road
Hi guys ,
I m new to Open foam and i ve installed openFOAM extend 4 in ubuntu 16.04 and centos7 following the steps in the link below ( and please note that i ve installed it from source code )
https://openfoamwiki.net/index.php/I...oam-extend-4.0
evrything were good . i started with the lid driven cavity tuto in the users guide but it happens at a Certain stage when i enter the :
postProcess -list
i get command not found
i tried the same with the the installed one on centos and still have the same issue ?!
Can you , guys, help me please !!
losiola is offline   Reply With Quote
Old   July 20, 2022, 13:49
NuclearLeaf's Avatar
Mario Zuber
NuclearLeaf is on a distinguished road
I know it's an old post but I ran into this issue myself (albeit on another installation version).
This solved my problem:
sudo apt install cmake
sudo apt-get install qt5-default
Then recompiling openfoam with ./Allwmake
NuclearLeaf is offline   Reply With Quote
[Gmsh] Insatlling gmsh from the source code-issue? CFD-Lover OpenFOAM Meshing & Mesh Conversion 20 June 12, 2018 07:39
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
