Wave tutorial
Like Tree2Likes
Old   June 6, 2018, 20:25
Exclamation Wave tutorial
Jeferson Souza
jasouza1974 is on a distinguished road
Dear all,
I'm trying to understand how to set wave parameters in the new openFoam 5.0 wave tutorial.
Basically, I do not understand what is the speed parameter. Is it the wave velocity? Description talk about "mean flow speed", but I don't know what it means?
For example for a wave with the following parameters
wave length = 65.4 m
period = 7.5 s
height = 1 m
how can I set up the waveVelocity boundary condition?
left
type waveVelocity;
origin (0 0 0);
direction (1 0 0);
speed ????? (what should I put here?);
waves
Airy
length 65.4;
amplitude 0.5;
phase 0;
angle 0;
scale constant 1;
crossScale constant 1;
Thanks,
jasouza1974 is offline   Reply With Quote
Old   June 7, 2018, 15:37
JNSN's Avatar
Jan
JNSN is on a distinguished road
Speed is an additional current, I.e. if you solve a ship sailing in waves with forward speed. In case you only want to have a wave without current, set speed to zero
aow likes this.
JNSN is offline   Reply With Quote
Old   June 12, 2018, 11:30
Jeferson Souza
Thanks a lot.
Old   September 25, 2018, 23:54
Ian
insane is on a distinguished road
Hi, Jeferson
I'm trying to understand the parameters of waveVelocity recently, but a few parameters confused me a lot
1) scale table ((1200 1) (1800 0));
2) scale and crossScale(I have never seen before)
3) note that speed does not mean wave velocity how to set it
any advice would be great appreciated
thanks in advance
insane is offline   Reply With Quote
Old   October 7, 2019, 05:26
Rasmus Iwersen
Rasmusiwersen is on a distinguished road
Originally Posted by jasouza1974 View Post
Dear all,
period = 7.5 s
where is the period specified?? I can see where wave length and the amplitude. However, the period doesn't seem to be specified anywhere.
Rasmusiwersen is offline   Reply With Quote
Old   April 6, 2020, 19:14
Thepsy20
Thepsy is on a distinguished road
did you find an answer to define the period ?
Thepsy is offline   Reply With Quote
Old   April 6, 2020, 21:46
Jeferson Souza
Actually, period can be obtained from the Dispersion Relationship. For a linear wave we have
sig^2 = g k tanh(k h)
sig = 2 Pi/T
k = 2 Pi/L
g -> gravity
L -> wave length
T -> wave period
Old   May 24, 2020, 07:27
chenlinghao
RiderCharles is on a distinguished road
Originally Posted by insane View Post
Hi, Jeferson
thanks in advance
I also encountered this problem.
Do you already know something about these parameters?
thanks for your sharing in advance。
RiderCharles is offline   Reply With Quote
Old   October 23, 2020, 11:34
nasa55 is on a distinguished road
Originally Posted by RiderCharles View Post
scale table means between 1200m and 1800m (in x direction) the wave should be damped. In other owrds, up to 1200, the wave has scale factor 1 and at 1800, the scale factor is 0 (no wave).
nasa55 is offline   Reply With Quote
Old   February 28, 2022, 12:36
Tony Zhang
zyfsoton is on a distinguished road
Hi, I am wondering if it is possible to set waves from one side of the domain e.g from the inlet boundary?
Currently, I am simulating the KCS model in calm water and waves using OpenFOAM v7.
Many thanks
Tony
zyfsoton is offline   Reply With Quote
Old   February 28, 2022, 13:21
Jeferson Souza
Hi, yes.
You can do it easily. I prefer to use the olaFlow (https://olaflow.github.io/) instead of interFoam.
olaFlow is kind of optimized to this kind of problems. Its compilation is also straight forward.
Old   February 28, 2022, 14:26
Many thanks
Tony
You can use funky SetField to define the boundary at the inlet.
Old   March 1, 2022, 07:53
Tony Zhang
Hi, yes.
Hi Jeferson,
Many thanks for your reply. But I think I have to use interFoam because I have modified the solver based on interFoam. I have successfully run the KCS in calm water and Stokes2 wave. Now I am hoping to simulate the KCS in waves and use the final state of calm water as the initial state of wave condition. For example, I ran the calm water case for 50s and take the 50s state as the initial state of stokes2 wave condition, but it seems didn't add wave on from 50s. I attached some pictures of wave elevation contours for wave condition.
Since in calm water just use setFields while in wave condition have to use setWave, I think I have changed all controlDict file and waveProperities file. But it seems wave is not added on from 50s.
And I am confused about the scale table ((4 1) (12 0)) located in waveProperties, I am hoping to let wave just pass through the hull from the right handside of my domain, how should I do? Please let me know if you need more information from me.
Many thanks
Tony
File Type: png Screenshot from 2022-02-27 18-05-38.png (142.5 KB, 65 views)
File Type: png Screenshot from 2022-02-27 18-09-20.png (124.4 KB, 47 views)
File Type: png Screenshot from 2022-02-27 18-09-55.png (120.8 KB, 48 views)
Old   March 1, 2022, 07:55
Tony Zhang
Hi, many thanks for your reply. I use setFields for my hull in calm water and then change to setWaves in wave conditons. Do you have any tutorial or case to use think funky setField to define the boundary at the inlet?
Many thanks
Tony
Old   March 1, 2022, 10:38
Jeferson Souza
I've never been able to validate the solution (comparing to the analytical wave solution) of the wave tutorial. That's why I recommended the olaFlow.
About the restart. Did you change the boundary conditions at the 50s folder?
Old   March 1, 2022, 10:51
Tony Zhang
Yes, the 50s folder contains the information of alpha_water, U, p_rgh and etc of the final state of calm water. Also, I copied these variables of initial state of wave condition(alpha_water.orig, U.orig, p_rgj.orig and etc) into 50s folder. Then I do renumberMesh, setWaves, decomposePar and then interFoam. But it doesn't add wave on.
Old   March 1, 2022, 11:25
Jeferson Souza
It's a long time that I did not run this kind of problem, but i think you should not run setWaves again.
Another thing, did you decomposed the right time? -> "decomposePar -latestTime"
Old   March 1, 2022, 13:03
Tony Zhang
Many thanks, I will give it a try and keep you updated!
Old   April 22, 2022, 10:20
Tony Zhang
Hi Jan,
nowadays I am simulating a ship in wave with forward speed. I am using openfoamv7 and the calculation conditions are as follows:
ship speed=1.588m/s, wave speed=2.602m/s, I modified the waveProperties file which is located at constant file as follows:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      waveProperties;
origin          (0 0 0);
direction       (-1 0 0);
speed           1.588;
waves
    Stokes2
        length      4.338;
        amplitude   0.038;
        phase       0;
        angle       0;
UxMean          -2.602;
UMean           ($UxMean 0 0);
scale           table ((10 1) (20 0));
But I am not sure whether this setup is right or not? Please correct me if I am wrong.
Many thanks for your help and best regards,
Tony
Old   April 22, 2022, 13:35
JNSN's Avatar
Jan
Hi Tony, what do you mean with wave velocity?
openfoam 5.0, speed, wave boundary conditions
need tutorial files(Simulation of Wave Generation in a Tank) gholamghar FLUENT 45 May 6, 2018 11:57
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
How to generate waves of particular wave height...please help nims FLUENT 0 September 21, 2010 03:48
Scaling up a wave energy converter - free surface flow mark_l CFX 3 February 17, 2010 17:57
need tutorial files(Simulation of Wave Generation in a Tank) gholamghar FLUENT 0 March 28, 2009 04:08
