Anton Afanassiev
Rep Power: 0 ![]() |
I have been trying to simulate a NREL 5MW reference turbine using rotorDiskSource. I seem to get good results when running on a single processor. But when I decompose and run, the turbine's wake completely disappears. I've noticed that in the decomposed case the rotorDiskSource output shows effective lift = 0, when in the single processor case it is around 100k. Code:
otorDisk output: min/max(AOA) = 1.65132, 1.71517 Effective drag = -5011.09 Effective lift = 0 GAMG: Solving for Ux, Initial residual = 1.00076e-06, Final residual = 1.00076e-06, No Iterations 0 GAMG: Solving for Uy, Initial residual = 7.42757e-06, Final residual = 7.42757e-06, No Iterations 0 GAMG: Solving for Uz, Initial residual = 7.49477e-06, Final residual = 7.49477e-06, No Iterations 0 GAMG: Solving for T, Initial residual = 2.87311e-06, Final residual = 2.87311e-06, No Iterations 0 GAMG: Solving for p_rgh, Initial residual = 0.000266345, Final residual = 2.55409e-06, No Iterations 18 time step continuity errors : sum local = 1.94881e-10, global = 1.05977e-15, cumulative = -1.00503e-09 GAMG: Solving for p_rgh, Initial residual = 6.00008e-06, Final residual = 9.16971e-07, No Iterations 6 time step continuity errors : sum local = 6.99648e-11, global = -5.42417e-15, cumulative = -1.00503e-09 ExecutionTime = 17.06 s ClockTime = 18 s Code:
#include "../meshSetup" numberOfSubdomains $nDomains; // method scotch; // method hierarchical; // method simple; method $method; // method metis; // method manual; // method multiLevel; // method structured; // does 2D decomposition of structured mesh multiLevelCoeffs { // Decomposition methods to apply in turn. This is like hierarchical but // fully general - every method can be used at every level. level0 { numberOfSubdomains 64; //method simple; //simpleCoeffs //{ // n (2 1 1); // delta 0.001; //} method scotch; } level1 { numberOfSubdomains 4; method scotch; } } // Desired output simpleCoeffs { n ($Sx $Sy $Sz); delta 0.001; } hierarchicalCoeffs { n (1 2 1); delta 0.001; order xyz; } metisCoeffs { /* processorWeights ( 1 1 1 1 ); */ } scotchCoeffs { //processorWeights //( // 1 // 1 // 1 // 1 //); //writeGraph true; //strategy "b"; } manualCoeffs { dataFile "decompositionData"; } structuredCoeffs { // Patches to do 2D decomposition on. Structured mesh only; cells have // to be in 'columns' on top of patches. patches (bottomPatch); } Below is the relevant portion of my fvOptions: Code:
disk { type rotorDisk; active on; rotorDiskCoeffs { selectionMode cellSet; cellSet turbine1; fields (U); // Names of fields on which to apply source nBlades 3; // Number of blades tipEffect 0.96; // Normalised radius above which lift = 0 inletFlowType local; // Inlet flow type specification geometryMode specified; origin (0 0 0); axis (1 0 0); refDirection (0 0 1); // Reference direction // - used as reference for psi angle rpm 12.1; trimModel fixedTrim; // fixed || targetForce rhoRef 1.225; rhoInf 1.225; fixedTrimCoeffs { theta0 0; theta1c 0; theta1s 0; } flapCoeffs { beta0 0; // Coning angle [deg] beta1c 0; // Lateral flapping coeff (cos coeff) beta2s 0; // Longitudinal flapping coeff (sin coeff) } |
Kisorthman Vimalakanthan
Rep Power: 15 ![]() |
Hi Jabbath,
I'm faced with the same issue? were you able to simulate the NREL5MW rotor with rotorDiskSource on parallel.. could you please share your files? many thanks in advance, Kind regards, Kishore
Kisorthman Vimalakanthan Dept. of Power and Propulsion Cranfield University Email: k.vimalakanthan@gmail.com |
Herpes Free Engineer
Rep Power: 12 ![]() |
Could you please open a bug-issue with a minimal reproducible example in https://develop.openfoam.com/? Many thanks.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
#4 | |
decomposepar, openfoam 4.1, wind turbine blade, wind turbines |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Discrepancy ensight slice and full data for parallel decomposed case | Japsor | OpenFOAM Bugs | 0 | August 27, 2013 04:47 |
Error reading new case | montag dp | FLUENT | 5 | September 15, 2011 06:00 |
decomposed case to 2-cores (Not working) | pkr | OpenFOAM Running, Solving & CFD | 32 | February 27, 2011 18:04 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 10:25 |
