Supersonic flow over a cylinder
Old   June 1, 2018, 14:11
Exclamation Supersonic flow over a cylinder
Vishish Behera
Vishish is on a distinguished road
I am simulating a supersonic laminar flow over a cylinder and this error has stalled me for a while/ I've already checked the other threads, and none of them worked so far.
What can be the problem?
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Reading thermophysical properties
Selecting thermodynamics package
type hePsiThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleInternalEnergy;
Reading field U
Creating turbulence model
Selecting turbulence model type laminar
Creating field kinetic energy K
No MRF models present
No finite volume options present
Starting time loop
Time = 5e-07
Courant Number mean: 0.0597729 max: 1.37857
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
PIMPLE: iteration 1
smoothSolver: Solving for Ux, Initial residual = 0.667594, Final residual = 0.239997, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 0.999981, Final residual = 4.26033e-07, No Iterations 3
smoothSolver: Solving for e, Initial residual = 1, Final residual = 9.68353e-06, No Iterations 116
[0] #0 Foam::error:rintStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[0] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:?
[0] #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:?
[0] #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
[0] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
[0] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
[0] #8 Foam::fvMatrix<double>::solve() at ??:?
[0] #9 ? at ??:?
[0] #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #11 ? at ??:?
Vishish is offline   Reply With Quote
Old   June 1, 2018, 16:04
clapointe is on a distinguished road
From the error output, you can see that Ux takes 1000 iterations and your CFL number is above 1. Decrease your initial timestep and max Co number as a first step to working out the problem.
Caelan
clapointe is offline   Reply With Quote
error, openfoam, sonicfoam
No vortex shedding for flow over cylinder at Re = 59 using pimpleFoam kaszt OpenFOAM Running, Solving & CFD 9 March 15, 2022 08:34
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 03:19
Flow through small cylinder recirculated inside larger cylinder. Keesie FLUENT 1 July 28, 2016 05:30
Jet in Supersonic Crossflow, controlling mass flow rate ChrisA OpenFOAM Running, Solving & CFD 3 November 13, 2012 19:20
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
