May 23, 2018, 04:06 |
Weird result by k omega SST
bingjr
Rep Power: 8 |
Dear Openfoam users,
I am doing the simulation of a diffuser by k omega SST model and I use simplefoam as the solver. We have tried many times with a few different settings. However, none of the results make sense,even there were irregular and strange flow profile (kind of like vortex) in some of the results. y+ is less than 1 here. Could you please have a look at my settings and give me some advice? Thanks. Here are my settings in each file. Note that the solver and k omega SST may not be replaced. Boundary condition frontAndBack empty bottom symmetry top wall inlet patch outlet patch Initial condition U The velocity at the inlet is fully-developed turbulent flow. Code:
inlet fixedValue value nonuniform List<vector> frontAndBack { type empty; } top { type noSlip; bottom { type symmetry; } outlet { type zeroGradient; } } P Code:
internalField uniform 0; boundaryField { frontAndBack { type empty; } top { type zeroGradient; } inlet { type zeroGradient; } bottom { type symmetry; } outlet { type fixedValue; value uniform 0; } } Code:
internalField uniform (we calculated it); boundaryField { frontAndBack { type empty; } top { type omegaWallFunction; value uniform (a very large value); } inlet { type fixedValue; value uniform (we calculated it); } bottom { type symmetry; } outlet { type zeroGradient; } } Code:
internalField uniform 0; boundaryField { frontAndBack { type empty; } top { type nutUSpaldingWallFunction; value uniform 0; } inlet { type calculated; value uniform 0; } bottom { type symmetry; } outlet { type calculated; value uniform 0; } } Code:
internalField uniform (we calculated it); boundaryField { frontAndBack { type empty; } top { type fixedValue; value uniform (a very small value); } inlet { type fixedValue; value uniform (we calculated it ); } bottom { type symmetry; } outlet { type zeroGradient; } } Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Fvsolution Code:
solvers { p { solver GAMG; tolerance 1e-06; relTol 0.01; smoother GaussSeidel; } "(U|k|omega)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-06; relTol 0.01; } } SIMPLE { nNonOrthogonalCorrectors 0; consistent yes; } relaxationFactors { fields { p 0.1; } equations { U 0.1; k 0.1; omega 0.1; } } We are looking forward to your reply. Thanks! Last edited by bingo641; May 23, 2018 at 08:04. |
May 23, 2018, 10:15 |
Jan
Rep Power: 20 |
not sure if this improves your results, but I suggest using Code:
kqRWallFunction Best regards, Jan |
May 23, 2018, 10:21 |
bingjr
Rep Power: 8 |
Hi Jan,
Thanks for your reply! Actually we tried several times with different relaxation factors. This is because sometimes the residual value changed greatly in value. In addition, since our y+ is expected to be less than 1, is it suitable to use this wall function? |
May 28, 2018, 00:05 |
#4 | |
Ben
Rep Power: 10 |
Boundary conditions for K and Omega in SST model | Ryan. | SU2 | 4 | July 23, 2021 03:55 |
K-Omega SST BC set up for omega and K | joneill053 | OpenFOAM Pre-Processing | 2 | July 10, 2017 15:29 |
T-Junction using rhoPimpleFoam (Simulation blows and weird result) | mecbe2002 | OpenFOAM Running, Solving & CFD | 4 | July 23, 2015 16:26 |
Omega goes infinity | callumso | OpenFOAM Running, Solving & CFD | 5 | October 2, 2013 08:52 |
Airfoil 2D, very weird result | Martin | FLUENT | 4 | June 13, 2007 13:21 |
