foam-extend 4.0. Problem with wingMotion tutorial and sixDoFRigidBodyDisplacement |
May 11, 2018, 05:13 |
Rep Power: 16 |
Dear Foamers,
I am trying to run the default wingMotion tutorial using sixDoFRigidBodyDisplacement in foam-extend 4.0. However, it seems to me that the body is only moving at the very first time step and then all motion ends. There is also no output regarding information about restraints, centre of mass etc. in the log file. I ran the tutorial in OpenFOAM 5.0 without a problem but can not get it to run in foam-extend 4.0. Any ideas? Thanks in advance. After some more tries I found that pimpleDyMFoam only moves the body at the first time step and then all movement is stopped. This is the same for sixDoFRigidBodyDisplacement or oscillatingDisplacement. edit: I somehow messed the installation up. pimpleFoam worked excellent so I did not consider this first but after reinstallation the problem ist solved. Last edited by Bazinga; May 28, 2018 at 05:34. |
December 14, 2024, 21:34 |
#2 | |
Rep Power: 4 |
I’m encountering the same issue as you with Foam-Extend-4.0. I’ve already tried reinstalling it multiple times, but the problem still persists. Could you kindly share your installation package with me? I’ve been struggling with this for a while and would really appreciate your help! Best regards, Gunther |
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL | AndoniBM | OpenFOAM Running, Solving & CFD | 2 | March 25, 2015 19:44 |
[snappyHexMesh] Problem with the turbineSiting tutorial and snappyHexMesh | Thaemos | OpenFOAM Meshing & Mesh Conversion | 0 | June 28, 2013 05:32 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 06:34 |
Help! Compiled UDF problem 4 Wave tank tutorial | Shane | FLUENT | 1 | September 3, 2010 03:32 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 10:57 |
