Foam fatal IO error: Cannot find patchField entry for movingWall |
May 9, 2018, 16:25 |
Yetkin
I am a newbie in OpenFoam. I am an electrical engineer, so I do not have much experience related with OpenFoam.
I am trying implement simulation of a journal bearing. I created the mesh but I am sure about the 'boundary' blockMeshDict and initial velocity 'U'. I defined fixed wall, moving walls and frontAndback. Then I defined the initial angular velocity in 'U' directory. However, when I am running openFoam I am getting the following error: 'Foam fatal IO error: Cannot find patchField entry for movingWall' I couldn't find why I am getting this error I created the mesh without boundary conditions. Normally, inner bearing pin should rotate inside but I could not implement the movement because something is wrong with 'boundary - blockMeshDict' and 'boundaryField - U'. The code is in the attachment. Any help would be great! Thanks. |
bearings, boundary condition, initial velocity field |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[OpenFOAM] Take derivative of mean velocity in paraFoam | hiuluom | ParaView | 13 | April 26, 2016 06:44 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
