Cannot find libtwoPhaseInterfaceProperties.so |
May 9, 2018, 04:01 |
Kahlil Fredrick Cui
Rep Power: 8 |
Greetings!
I have made some modifications to interFoam to accommodate coupling with DEM. It is more like adding some files rather than changing anything actually. The code is run through the DEM commands and it calls the openFoam libraries to process the CFD part. The problem is I have a coupling library which calls another shared library libtwoPhaseInterfaceProperties.so which cannot be found. More specifically, the error goes like this: Code:
libtwoPhaseInterfaceProperties.so: cannot open shared object file: No such file or directory I would truly appreciate any help. Thank you very much in advance! Kahlil Cui |
interfoam |
[foam-extend.org] 3.2 Installation in Debian 8.5 | jsm | OpenFOAM Installation | 2 | June 19, 2016 10:53 |
How to make a code parallel? | Bruno Machado | Fluent UDF and Scheme Programming | 15 | May 27, 2016 09:18 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 06:32 |
