Can't convert my mesh created in Gmsh to OpenFOAM |
May 2, 2018, 05:28 |
Crystal
Hi everyone!
My name is Crystal and I have an issue in converting the mesh that I created in Gmsh to OpenFoam. I have tried using th commands "gmshToFoam Part2.msh" and also "fluentMeshToFoam Part2.msh" but they keep saying error. I'm currently using Gmsh version 2.11.0 (64bit Linux) and OpenFOAM-in-Box-18.02. I'm open to any suggestions or solutions so please feel free to help me out or ask me any questions for any clarification. Here are the attached file: |
May 2, 2018, 11:42 |
Rep Power: 15 |
Can you post the error (or the full case, and not just the .msh file)? I've used gmshToFoam recently for OF4x and gmsh2.12 and it worked fine. The key is to check the boundaries in constant/polyMesh/boundaries to make sure that they're correct -- if I recall correctly they were all changed to "patch" type by the converter.
Caelan |
gmsh to openfoam |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
[Other] how to convert a mesh drawn in matlab to a format which can be used in OpenFOAM | jali | OpenFOAM Meshing & Mesh Conversion | 3 | July 19, 2017 21:16 |
Importing Mesh from GMsh to OpenFoam | bmaldi | OpenFOAM Running, Solving & CFD | 1 | May 4, 2016 12:57 |
[Other] Error while tring to convert mesh generated in salome to openfoam | Arjun Jayakumar | OpenFOAM Meshing & Mesh Conversion | 0 | October 10, 2014 09:46 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
