Inflow moving in wrong direction
Old   April 28, 2018, 02:57
Exclamation Inflow moving in wrong direction
Kahlil Fredrick Cui
cuikahlil is on a distinguished road
Greetings!
I am simulating a very simple scenario of fluid entering through an inflow patch, overcoming a static boundary and exiting through an outflow. Very similar to the weir overflow in interfoam. My problem is that, instead of flowing in the x-direction, the flow goes up! I tried my boundary conditions on the blockMesh of the dambreak example, and it seemed to work fine, indicating that the problem is with my geometry.
Here is my blockMesh
convertToMeters 1;
vertices
    (0 0 0)//0
    (2 0 0)//1
    (3 0 0)//2
    (5 0 0)//3
    (0 1 0)//4
    (2 1 0)//5
    (3 1 0)//6
    (5 1 0)//7
    (0 1.5 0)//8
    (2 1.5 0)//9
    (3 1.5 0)//10
    (5 1.5 0)//11
    (0 5 0)//12
    (2 5 0)//13
    (3 5 0)//14
    (5 5 0)//15
    (0 0 0.5)//16
    (2 0 0.5)//17
    (3 0 0.5)//18
    (5 0 0.5)//19
    (0 1 0.5)//20
    (2 1 0.5)//21
    (3 1 0.5)//22
    (5 1 0.5)//23
    (0 1.5 0.5)//24
    (2 1.5 0.5)//25
    (3 1.5 0.5)//26
    (5 1.5 0.5)//27
    (0 5 0.5)//28
    (2 5 0.5)//29
    (3 5 0.5)//30
    (5 5 0.5)//31
blocks
    hex (0 1 5 4 16 17 21 20) (30 30 15) simpleGrading (1 1 1)
    hex (2 3 7 6 18 19 23 22) (30 30 15) simpleGrading (1 1 1)
    hex (4 5 9 8 20 21 25 24) (30 15 15) simpleGrading (1 1 1)
    hex (6 7 11 10 22 23 27 26) (30 15 15) simpleGrading (1 1 1)
    hex (8 9 13 12 24 25 29 28) (30 60 15) simpleGrading (1 1 1)
    hex (9 10 14 13 25 26 30 29) (30 60 15) simpleGrading (1 1 1)
    hex (10 11 15 14 26 27 31 30) (30 60 15) simpleGrading (1 1 1)
edges
boundary
    inlet
	type patch;
	faces
	    (0 16 20 4)
    outlet
	type patch;
	faces
	    (7 23 19 3)
    leftWall
        type wall;
        faces
            (4 20 24 8)
            (8 24 28 12)
    rightWall
        type wall;
        faces
            (11 27 23 7)
            (15 31 27 11)
    lowerWall
        type wall;
        faces
            (0 1 17 16)
            (1 5 21 17)
            (9 10 26 25)
            (10 6 22 26)
            (6 2 18 22)
            (2 3 19 18)
    atmosphere
        type patch;
        faces
            (12 28 29 13)
            (14 13 29 30)
            (14 30 31 15)
As you can see it is extremely simple. Its pretty much like an overgrown dambreak which is why i don't understand the problem.
To further clarify my U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            fixedValue;
	value		uniform (1 0 0);
    outlet
        type            zeroGradient;
    leftWall
        type            fixedValue;
        value           uniform (0 0 0);
    rightWall
        type            fixedValue;
    lowerWall
        type            fixedValue;
    atmosphere
        type            pressureInletOutletVelocity;
    defaultFaces
        type            empty;
and p:
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
	type		zeroGradient;
    outlet
        type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
    leftWall
        type            fixedFluxPressure;
        value           uniform 0;
    rightWall
        value           uniform 0;
    lowerWall
        value           uniform 0;
    atmosphere
        type            totalPressure;
        p0              uniform 0;
        U               U;
        phi             phi;
        rho             rho;
        psi             none;
        gamma           1;
        value           uniform 0;
    defaultFaces
        type            empty;
are as follows.
The simulation results are attached as an image.
The error might be very simple. If you could just point me in the right direction, i'd be really grateful!
cuikahlil is offline   Reply With Quote
Old   May 1, 2018, 15:21
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hi there,
Could you upload a stripped version of your case with all the BC's. I'm thinking perhaps your alpha field might have issues? If you suspect your geometry, does checkmesh work?
mturcios777 is offline   Reply With Quote
Old   May 1, 2018, 22:22
Kahlil Fredrick Cui
Hello!
Thanks for the response, but I already figured out the error. I should've updated this question then. I apologize.
I actually found out that one of my floor faces was undefined. Weird thing was it didn't turn up during checkMesh. When I re-created the whole mesh, I found out I neglected one face. I also didn't expect the fluid to behave that way as a reaction to a missing face.
Hope my error becomes a lesson for someone else.
dambreak, inflow bc, outflow bc
Flow Direction: normal to boundary!!! Atit CFX 1 August 2, 2015 14:42
[snappyHexMesh] jagged, ragged edges... ziemowitzima OpenFOAM Meshing & Mesh Conversion 138 July 24, 2012 00:41
Moving mesh in Fluent fivos FLUENT 0 April 2, 2010 10:45
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
moving cylinder blur boy Main CFD Forum 4 October 12, 2001 06:32
