April 18, 2018, 11:58 |
reconstructPar error with binary format data
Bashar
Rep Power: 11 |
Sorry to post this but I searched the forum and didn't find something that will solve my issue. My problem is that I am getting the following error , with openFoam 5.x, when I tried to reconstruct my case that I used binary format in controlDict to write the data : Code:
Reconstructing fields for mesh region0 --> FOAM FATAL IO ERROR: Expected a ')' while reading binaryBlock, found on line 20 an error file: /media/bashar/Bashar/Research/Free_Surface/VOF_1.5cm_75cm/constant/polyMesh/faces at line 20. From function Foam::Istream& Foam::Istream::readEnd(const char*) in file db/IOstreams/IOstreams/Istream.C at line 109. FOAM exiting Code:
\*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application interFoam; startFrom latestTime;//startTime; startTime 0.0000; stopAt endTime;//writeNow;//endTime; endTime 40; deltaT 0.001; writeControl runTime; writeInterval 0.5; purgeWrite 0; writeFormat binary;//ascii; writePrecision 6; writeCompression uncompressed; timeFormat fixed; timePrecision 4; runTimeModifiable yes; adjustTimeStep yes; maxCo 0.5; maxAlphaCo 0.25; maxDeltaT 1; //stopAt writeNow; I tried on of the suggestions on the forum to convert the data from binary to ASCII but again I got this error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-19576d14a099 Exec : foamFormatConvert Date : Apr 18 2018 Time : 10:53:50 Host : "fluid10" PID : 26981 I/O : uncollated Case : /media/bashar/Bashar/Research/Free_Surface/VOF_1.5cm_75cm nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Time = constant Reading labelList : owner --> FOAM FATAL IO ERROR: Expected a ')' while reading binaryBlock, found on line 21 an error file: /media/bashar/Bashar/Research/Free_Surface/VOF_1.5cm_75cm/constant/polyMesh/owner at line 21. From function Foam::Istream& Foam::Istream::readEnd(const char*) in file db/IOstreams/IOstreams/Istream.C at line 109. FOAM exiting I tried to execute the foamFormatConvert tool excluding the constant folder since it always complain about it in the error, I got this error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-19576d14a099 Exec : foamFormatConvert -noConstant Date : Apr 18 2018 Time : 10:56:38 Host : "fluid10" PID : 27016 I/O : uncollated Case : /media/bashar/Bashar/Research/Free_Surface/VOF_1.5cm_75cm nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Excluding the constant directory. Create time Time = 0.0000 Reading volScalarField : nut Writing nut Reading volScalarField : alpha.water Writing alpha.water Reading volVectorField : U Writing U Reading volVectorField : U.org Writing U.org Reading volScalarField : nuTilda Writing nuTilda Reading volScalarField : alpha.water.org Writing alpha.water.org Reading volScalarField : p_rgh Writing p_rgh Create polyMesh for time = 0.0000 --> FOAM FATAL IO ERROR: Expected a ')' while reading binaryBlock, found on line 20 an error file: /media/bashar/Bashar/Research/Free_Surface/VOF_1.5cm_75cm/constant/polyMesh/faces at line 20. From function Foam::Istream& Foam::Istream::readEnd(const char*) in file db/IOstreams/IOstreams/Istream.C at line 109. FOAM exiting Regards, Bashar |
April 22, 2021, 12:53 |
Andrea
Hi Bashar,
sorry to bother you on this old thread, did you solve the issue? Because I am experiencing the same on OF7 and Ubuntu 20.10 Thanks! |
[General] A "clean" solution to export binary ensight gold format from Fortran to Paraview? | flotus1 | ParaView | 1 | June 23, 2015 12:59 |
NASTRAN Data format | Srinivasan Arunajatesan | Main CFD Forum | 1 | January 2, 2014 07:20 |
studying a valve case | mina.basta | OpenFOAM | 33 | August 30, 2013 05:46 |
Best format for simulation data? | cbisw | Main CFD Forum | 9 | May 30, 2011 03:38 |
Fieldview Data Format?? | Choong K. Yoo | FieldView | 0 | August 23, 1999 20:59 |
