April 15, 2018, 13:30 |
Setting triangular region in the mesh
fluidflowsteel
Rep Power: 10 |
through the setFields dictionary, one can set an initial condition for a box region. Can anyone tell me about how can i set an initial condition for a triangular region or rather how can i set a triangular region in the mesh ? With regards, |
April 16, 2018, 13:55 |
Geir Karlsen
Rep Power: 13 |
funkySetFields (swak4foam) is probably easiest, but you might get what you need from setting field values with "rotatedBoxToCell" and then resetting part of the region with an ordinary "boxToCell" in the setFieldsDict
help with setting up overset mesh | calv | FLUENT | 0 | May 14, 2017 09:12 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
