March 23, 2018, 18:42 |
pimpleFoam blows up
Hi guys,
I am running a simple case with pimpleFoam. I get way too high pressure gradient and velocity. The flow is laminar. My boundary conditions are: Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } upperMembrane { type zeroGradient; } lowerMembrane { type zeroGradient; } spacers { type zeroGradient; } so1 { type zeroGradient; } so2 { type zeroGradient; } } Code:
internalField uniform (0.1 0 0); boundaryField { inlet { type fixedValue; value uniform (0.1 0 0); } outlet { type zeroGradient; } upperMembrane { type fixedValue; value uniform (0 0 0); } lowerMembrane { type fixedValue; value uniform (0 0 0); } spacers { type fixedValue; value uniform (0 0 0); } so1 { type fixedValue; value uniform (0 0 0); } so2 { type fixedValue; value uniform (0 0 0); } } And my checkMesh looks like this: Code:
Mesh stats points: 2969007 faces: 30898219 internal faces: 29458877 cells: 15089274 faces per cell: 4 boundary patches: 7 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 15089274 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 47683 24840 ok (non-closed singly connected) lowerMembrane 439090 221519 ok (non-closed singly connected) outlet 47664 24830 ok (non-closed singly connected) so1 47666 24833 ok (non-closed singly connected) so2 47727 24869 ok (non-closed singly connected) spacers 370831 189841 ok (non-closed singly connected) upperMembrane 438681 221236 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (3.5e-05 3.5e-05 -2.273737e-13) (0.00446501 0.004465 0.001) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.761814e-15 -3.603008e-16 -2.208104e-13) OK. Max cell openness = 3.941394e-16 OK. Max aspect ratio = 18.79829 OK. Minimum face area = 1.058019e-12. Maximum face area = 2.042148e-09. Face area magnitudes OK. Min volume = 1.351823e-18. Max volume = 3.658189e-14. Total volume = 1.819464e-08. Cell volumes OK. Mesh non-orthogonality Max: 78.37398 average: 11.61264 *Number of severely non-orthogonal (> 70 degrees) faces: 1584. Non-orthogonality check OK. <<Writing 1584 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 1.393563 OK. Coupled point location match (average 0) OK. Mesh OK. Code:
solvers { p { solver GAMG; tolerance 1e-7; relTol 0.01; //Iter 20; smoother DICGaussSeidel; } pFinal { $p; relTol 0; } "(U|k|epsilon)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-05; relTol 0.1; } "(U|k|epsilon)Final" { $U; relTol 0; } } Thx. |
March 24, 2018, 01:08 |
Uwe Pilz
Rep Power: 15 |
What you show from your case looks good.
I recommend to set the initial field velocity to 0, write the results at every time step and look what happens. If the instability arises from the region where the mesh is unfavorable you have it.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
blowing up, pimplefoam |
naca12 laminar pimpleFoam | uni | OpenFOAM Running, Solving & CFD | 2 | March 17, 2018 07:17 |
PimpleFoam: Solver Crashes for simple laminar flow | mayank.dce2k7 | OpenFOAM Running, Solving & CFD | 0 | May 1, 2014 20:53 |
pimpleFoam blows:calculating laminar flow field | mayank.dce2k7 | OpenFOAM Programming & Development | 1 | May 1, 2014 15:38 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Differences simpleFoam vs. pimpleFoam / RASModel.H vs turbulenceModel.H | uli | OpenFOAM Programming & Development | 7 | January 26, 2013 15:01 |
