Regarding problem with the buoyantBoussinesqPimpleFoam solver.
Old   March 21, 2018, 09:38
Default Regarding problem with the buoyantBoussinesqPimpleFoam solver.
Vishwajit Kumar
tintintk is on a distinguished road
Hello everyone.
I am trying to simulate flow in a nozzle using the buoyantBoussinesqPimpleFoam solver. But at the outflow i am getting back-flow. I have tried all the possible boundary condition.
I am also attaching the case file for the reference and the screenshot the problem that i am getting.
the screen shot attached shows the problem at the outlet..where instead of getting the fully developed profile i am getting two recirculating zones.
Thank you in advance.
tintintk is offline   Reply With Quote
Old   March 22, 2018, 22:41
clapointe is on a distinguished road
Try an inletOutlet condition for your velocity at the outlet.
Caelan
clapointe is offline   Reply With Quote
Old   March 23, 2018, 01:57
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
If you use an outflow b.c. you should have an outflow stream there: The flow should not contain any backflow components. The flow property you set (zeroGradient) should be realized by the flow itself.
I recommend to simulate a longer region for stabilizing the flow. Usual, 10 times the size of obstacles is the required minimum. You don't have an obstacle, so I recommend 10 times the size of the large eddies.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 26, 2018, 02:20
Vishwajit Kumar
Thank you for the suggestions. I will try to implement it.
Vishwajit Kumar
Caelan
I have also tried this boundary condition but of no use.
boundarycondition, buoyantboussinesq, openfoam, pimplefoam
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
mesh.update problem in a new FSI solver ICL OpenFOAM 0 October 8, 2011 15:16
Compilation problem after modifying a solver. PetSul OpenFOAM Running, Solving & CFD 2 October 1, 2009 18:28
patching problem unsteady solver yellow-stuff Main CFD Forum 0 September 25, 2009 02:26
Coupled solver energy equation problem lucioantonio FLUENT 0 April 3, 2009 11:21
