March 21, 2018, 03:03 |
Warning after paraFoam in foam-extend
Jiadong Wang
Rep Power: 8 |
I recently installed the foam-extend 4.0 in the Ubuntu 16.04. The installation is ok, I suppose. But every time I run paraFoam in terminal, there will be a notice: "Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed!" By the way, I have no problem running paraFoam in my OpenFoam 5.0. I try to find some information about this error, but nothing is available. Anyone else encounters such a problem? I'll appreciate any information. Thank you. |
March 21, 2018, 03:09 |
Jiadong Wang
Rep Power: 8 |
When I run paraFoam, Paraview work normally and everything else is also ok.
But when I close the ParaView, the warning appear in terminal. |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
