weird pressure and turbulent intensity when using |
Rep Power: 9 ![]() |
hello
I have a big trouble when I using timeVaryingMappedFixedValue.in the /constant/boundayData/inlet/,I put 30000 directory and every directry only contain the U.the deltaT of the inflowData is 0.0001,and my calculating deltaT is also 0.0001,the simulation time is 3 seconds.That means I don't need time interpolation in the inflow data.and in my "points" file,I set 156*56points,so I think every grid on the inlet face can get the data. my case is a 3d rectangle ,and in my uploading picture,the left side in the inlet and rightside is the outlet. When I check the result I find the pressure field around the inlet boundary is very weird (looks like discontinuous).and the turbulent intensity is obviouly less than the inflow date.But actually the timeVaryingMappedFixedValue does works. I upload my picture of my pressure field. Does anyone can help me,I already struggle with this trouble for 1 month.: And I have such question. 1. does timeVaryingMappedFixedValue can give a smooth inflow ?what's meaning of the "mapped"? ![]() 2.do I have to add the "p" file when I use timeVaryingMappedFixedValue? |
Timofey Mukha
Rep Power: 14 ![]() |
1. Pressure fluctuations near the inlet is a common problem with inflow generation. It is caused by the fact that the solver attempts to enforce a divergence-free velocity field.
Mapped reffers to the fact that the bc can interpolate in space from the points where u provide the data to the face centres of the patch. 2. No, if u provide velocity data the pressure should be set to zero gradient. |
Dear tiam
Thank your replying and sorry for my reply late. In my case I use thetimeVaryingMappedFixedValue BC .If I use tetra unstructure mesh,the turbulent intensity look likes be tweaked and become strange.but when I use hex structure mesh grid system which parallel with inflow direction,the turbulent intensity can be kept very well,Do you know why such condition will appear? Sincerely Tang |
Uwe Pilz
Rep Power: 15 ![]() |
Unstructured meshes are most often triangular ones. You have a linear approach here, which is very diffusive. I don't recommend triangular meshes for serious calculations.
Hex meshes have a quadratic approach and are much less diffusive. It is much more expansive to get a local mesh refining with hex meshes, however.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Dear Uwe Pilz
Thank your replying~! |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
Pressure work term in turbulent K.E. equation | lost.identity | Main CFD Forum | 0 | March 8, 2011 12:21 |
Turbulent intensity for pressure Outlet Boundary condition | Mohsin | FLUENT | 1 | April 30, 2010 10:36 |
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel | nuimlabib | Main CFD Forum | 0 | August 4, 2009 00:05 |
