Problem with cavity tutorial
Old   March 16, 2018, 23:35
Default Problem with cavity tutorial
John Smith
Heisenflower is on a distinguished road
Hello everyone, I'm having some trouble with the cavity tutorial. duh
I'm following this guide right here: http://web.student.chalmers.se/group...psAndCases.pdf
I started having problems with the instructions at slide 23. The first step is to copy the icoFoam cavity tutorial to the run directory. It follows this two commands:
cp -r $FOAM_TUTORIALS/icoFoam/cavity $FOAM_RUN
cd $FOAM_RUN/cavity
However, when I try the cp command, I get this response:
cannot create directory '/home/user/OpenFOAM/user-dev-18.02-cfdsupport/run': No such file or directory
Indeed, when i run 'ls' there is no such file or directory. There is no OpenFOAM directory in my home, only OpenFOAM-in-Box-18.02. I suppose that it would work if I could swap
for
/home/user/OpenFOAM-in-Box.18.02/user-dev-18.02-cfdsupport/run
Does anyone know a way to do it?
Thank you for your time, and I'm sorry if this is a dumb question, please bare with me lol.
Heisenflower is offline   Reply With Quote
Old   March 17, 2018, 04:05
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
It seems your $FOAM_RUN is not set correctly. You are free to note the real path instead.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 18, 2018, 00:11
John Smith
Did that. Now when I try to run blockMesh, it returns me --> FOAM FATAL ERROR:
cannot find file "/home/user/OpenFOAM-in-Box-18.02/user-dev-18.02-cfdsupport/run/system/controlDict
I went looking for a 'system' directory in my OpenFOAM-in-Box.18.02 and found a whole bunch of results. Which one should I paste there?
Edit: It worked by placing my cavity system directory in ' /home/user/OpenFOAM-in-Box-18.02/user-dev-18.02-cfdsupport/run/ '. Then, the new error was ' cannot find file "/home/samyr/system/controlDict" ' . It was solved by following the same procedure. The blockMesh finally worked.
But I still dont understand why bash is searching for the system directory in those places. Specially at my home directory.
Thanks for the help so far
Old   March 18, 2018, 03:31
piu58's Avatar
Uwe Pilz
blockMesh looks in ./system for blockMeshDict.
Normally a case is establisehd as
run - <myFolder> - 0
                 - system
                 - constant
Uwe Pilz
Old   March 26, 2018, 12:13
Joaquín Neira
cojua8 is on a distinguished road
In file etc/bashrc, line 132 you may set WM_PROJECT_USER_DIR:
export WM_PROJECT_USER_DIR=your/custom/dir
here you may use any environment variables such as $HOME, $WM_PROJECT, $WM_PROJECT_VERSION, etc.
Then, in file etc/config.sh/settings, line 182 you may delete the /run part or just leave it there.
Make sure your directory exists or just create it in terminal:
mkdir -p $FOAM_RUN
This way, $FOAM_RUN is set to your custom run dir.
Hope this helps
cojua8 is offline   Reply With Quote
Convergence problem in 2D cavity problem dreamz Main CFD Forum 0 December 9, 2013 18:55
Viscositymodel tutorial, problems when changing test case to cavity sur4j OpenFOAM Programming & Development 1 December 8, 2013 10:53
Vessel tutorial problem hosseinhgf CFX 1 March 17, 2013 12:39
[OpenFOAM] display panal dosn't refresh in tutorial 2.1 Cavity kEpsilon ParaView 0 February 27, 2012 11:43
radiation problem for square cavity using fluent john Main CFD Forum 0 September 30, 2005 08:40
