February 27, 2018, 09:45 |
Pre-Processing using ANSA
christian rossi
Rep Power: 8 |
Hi everyone,
I'm an OpenFOAM's new user and I am trying to simulate the typical case of a laminar flow around a cylinder with heat transfer (3D). I created the geometries (.igs) of the two different subdomains using CATIA V5 and then I meshed them using ANSA (i am also a new user too). I have seen that with ANSA it is possible to set up an OpenFOAM case and after the geometries have been meshed, I tried to assign the BCs using the BC TOOLS (OpenFOAM DECKS) but as I export the case as "OpenFOAM Output", the "boundary" file generated in the PolyMesh directory does not include my BCs. Anyone could help me, please? Thank you. |
February 28, 2018, 03:50 |
Anton Kidess
Rep Power: 30 |
The boundary file is not supposed to include your physical BCs.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
February 28, 2018, 04:36 |
Vangelis Skaperdas
Rep Power: 21 |
Dear Christian
You can setup your BCs in ANSA for OpenFOAM. I suggest you have a look at the CFD tutorial Catalyst for OpenFOAM You should launch ANSA in CFD mode from the launcher. There is also a UDF that sets up automatically the boundary conditions on all PIDs based on some user input parameters. Hope this helps Best regards Vangelis |
March 7, 2018, 08:41 |
christian rossi
Rep Power: 8 |
Dear Vangelis,
Thank you very much for your hint! Just a question...Do you know what type of BC I have to use in order to get the exchange of informations between the interface air-solid? I was thinking to implement in my script constant/cylinder/polyMesh/boundary a BC called mappedWall but I don't know what sampleRegion and samplePatch stand for. CYLINDER_GAMMA { type mappedWall; sampleMode nearestPatchFace; sampleRegion ; samplePatch ; startFace 3780; nFaces 288; } best regards, Christian |
Proplems preprocessing (connecting mesh, feature line detection) | 19Karloss79 | STAR-CCM+ | 4 | April 21, 2017 11:39 |
[ICEM] Pre inlfation layer settings | Jeroenm | ANSYS Meshing & Geometry | 0 | September 29, 2016 04:22 |
a pre processing problem! | sinatahmooresi | OpenFOAM Pre-Processing | 1 | March 7, 2016 04:41 |
DEM - Pre Processing - Joining two separate mesh regions after some iterations | yesaswi92 | STAR-CCM+ | 0 | August 27, 2014 13:03 |
PRE and POST processing package | Astrid Barros | Main CFD Forum | 6 | November 16, 2000 11:31 |
